V8 Long Stroke for high Boost
Old Jun 20, 2022 | 06:50 AM
Animale's Avatar
Default V8 Long Stroke for high Boost
Hi all guys, I had this doubt that I would like to share with you to know your thoughts on it, and if possible, to know if anyone has had any experiences on it.
In the boost usually engines with a large thickness of the cylinder walls are preferred, I have seen on average, that around the boost, for example, many use the lsx 427 instead of the lsx 454, I guess it is for the smaller bore and therefore a greater thickness of the walls, and consequently a greater solidity of the block under high boost.
So by logic, building an engine for high boost, wouldn't it be convenient to just increase the stroke, using dedicated connecting rods and crankshaft, instead of increasing the bores? It would increase the displacement, and maintain a good block strength under high boost .............. why then around, the majority increase the bore?
Old Jun 20, 2022 | 07:13 AM
Shownomercy's Avatar
Man-Crush Warning
Usually means less piston material above conrod
Old Jun 20, 2022 | 07:31 AM
Animale's Avatar
Please can you explain better? Thank you so much for the response
Old Jun 20, 2022 | 08:35 AM
BCNUL8R's Avatar
I personally prefer more bore and less stroke.
Old Jun 20, 2022 | 09:23 AM
Jwooky's Avatar
Longer strokes will drive higher piston speeds at the same RPM, more frictional looses.
that’s typically why most do the opposite, larger bores to get the higher displacement.
Old Jun 20, 2022 | 09:47 AM
Black_Sunshine_99's Avatar
Big bore, short stroke is ideal.
Mike Moran built a 5" bore space big bore BBC with a short stroke for his TT combo, makes stupid power.
People don't usually boost the LS 454 because the gasket between the cylinder bores is really, really thin.
Boosted 440", 427" and 388" are way more common mostly because turbo engines like to rev, big stroke means big piston speed means big frictional losses and limited rpm.
Hell there are guys out there like Capizzi making 1,300-1,400hp on sbe 5.3's at 8,500+ rpm.
Old Jun 20, 2022 | 02:54 PM
AwesomeAuto's Avatar
Longer stroke usually means more block side loading in combination with higher piston speeds and reduced piston material, putting more stress on everything.
With blocks that have big bore spacing and tall decks, it is less of an issue than with an LS.
Running less displacement and more boost is always an option. V8 guys are a decade behind import guys in that ideology.
Old Jun 21, 2022 | 05:20 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've been seeing a shift in the scene to staying around 3.622 stroke, I'm seeing alot of 388 cid combos out there now. Brian Tooley sure likes not adding stroke.
Old Jun 22, 2022 | 03:57 AM
BCNUL8R's Avatar
This is an extreme example, but Steve Morris covers why his long stroke/rod combo has this issue and his shorter stroke combo's do not...
Old Jun 22, 2022 | 08:59 PM
Animale's Avatar
thanks everyone for the answers guys, they were very useful, do you think an engine with the same bore and stroke would be good for an american v8? It would combine the advantage of having a good thickness of the cylinder walls and a not too long stroke
Old Jun 23, 2022 | 09:37 AM
I think what you talking about is engine over square versus under square.
- Over Square is when the cylinder bore is wider than the stroke. (High revving, lower torque production)
- Under Square is wen the cylinder bore is narrower than the stroke. (Low revving, higher torque production)
Great example is the 5.3 LS, bore is 3.780 inches and stroke is 3.622 inches so an over square design that incorporates a thick cylinder wall.
Now if we toss a stroker crank shaft in with a 4.00" stroke we get 363ci and an under square design which as we all know with strokers makes more torque but won't have the rpm of the original 5.3 crank.
Old Jun 23, 2022 | 12:03 PM
LS1Tech Co-Founder
race car ls guys always go for more bore and better cylinder heads.
Old Jun 24, 2022 | 07:57 PM
Animale's Avatar
thanks again guys. At this point, my doubt is what is the thickness of the block walls needed to effectively sustain the sustained boost? Approximately 35-45 psi, again considering an iron block
Old Jun 25, 2022 | 12:29 PM
LS1Tech Co-Founder
4 bolt block?
Old Jun 25, 2022 | 05:50 PM
jester1's Avatar
Back in the day we ran a very short stroke BBC Olds heads 430 cI was a nitrous engine that eventually turned Procharged. Engine builder was out of Chicago his name escapes me now. High RPM, small cubes for weight break, big bore for heads. Insane little engine it was.
Old Jun 27, 2022 | 12:42 AM
Animale's Avatar
4 bolt block?
the number of bolts is relative, if I'm not mistaken the Dart Big M should be 4 bolts, but it supports more than 3000 horsepower, I'm not sure though
Old Jun 27, 2022 | 11:02 AM
3 window's Avatar
That was a killer setup back in the day. Merkel’s out of NY ran a short stroke, small cube big block (430 cubes or so) that was turbo’d in NMCA Super Street. I recall some 7.70s if I’m not mistaken. That was back in ‘95ish or 96.
Old Jun 27, 2022 | 10:41 PM
jester1's Avatar
Ironic, if I recall correctly fastest pass was 7.70@3660lbs in 07' I think.
Ended up in a light chassis with a F3 after SM got their hands on it.
Old Jun 28, 2022 | 08:23 AM
Forcefed86's Avatar
The block is very relevant. Let us know what block you plan on using and a power goal/intended application/ET/Weight etc. (IE drag car, 1000hp, stock block, 3000lbs 8.50's) Then we could suggest a bore/stroke. If you are talking factory LS 4-bolt blocks, then you leave them alone. There already isn't enough meat between the cyls on the 6.0 blocks for big power and stroking them pulls the piston out of the bore and rocks them, additional sideloads, etc... If you are running a tall deck aftermarket block, then that's much different! They are designed to handle greater bores/strokes. All comes down to cubic dollars in the end. If you want a "big" motor you pay "big" $. Which may or may not be necessary depending on your power/ET goal.
Old Jun 28, 2022 | 11:34 AM
LS1Tech Co-Founder
Animale what are you thinking to build, an LS or a Dart big M?
