Best coils for boosted Ls?
Old Jul 28, 2022 | 12:41 PM
  #41
SLOW SEDAN's Avatar
D581's on this setup w methanol on 41lbs. 5.3 107mm (not an SBE and heads had work). Reportedly went quicker, but saw it did a 4.50 at ls fest before it crashed.
Hellbesnts10 also went 6.80@209 on D581's on M1.
Indeed they work! The mustang looks to be a budget build, if you have an on3 turbo, stock manifold, etc you probably aren't going to spend a bunch on ignition upgrades if the OEM stuff is working. Nothing against it, I think its awesome. Other guys like to splurge off the hit on the build so they don't have to upgrade down the road, and sometimes (and dare I saw often) they aren't any faster. Some of those lightweight chassis are quick without having to make a ton of power, tube fox can get away with 1100hp and crack 4.5's while the guy that wants a street car that runs 4.5's has to make more like 1500. Hellbents car is just insane, is it his now or he was doing the tuning for Adkins if I recall?
Old Jul 30, 2022 | 12:47 AM
  #42
jayyyw's Avatar
Originally Posted by IGN-1A
You are correct, a N/A SPG of .065 is fine and also fine for 200 KPA boost pressure.
Another tip, use silicon grease on the plug boot.
What's the gain of using a larger gap? Better burn? More HP? More TQ? All of the above?
Old Jul 30, 2022 | 12:18 PM
  #43
IGN-1A's Avatar
Default Spark Energy Release
The small SPG of .016" can allow for a long ARC Duration even with the energy release of stock GM coils (100mj)
This can be a waste of energy due to the fact that the sparkplug will continue to arc AFTER combustion is complete.
A larger SPG of .045" - .065" will produce an ARC time better suited to ignite the fuel/air mixture when the piston is in the best position.
This will increase engine torque.
The LS-1 Tech users who fit the IGN-1A coil report an increase of 18-22 HP with a 500 HP engine.
They also have reported better throttle response and an increase in MPG.
Old Aug 6, 2022 | 08:42 PM
  #44
jayyyw's Avatar
Maybe I'll try to increase gap and see if there's a difference. I run my plugs out of the box, roughly .035" in an NA application. I have smart coils fitted.
Old Aug 17, 2022 | 10:25 PM
  #45
IGN-1A's Avatar
Default Ign-1a spg
Hi Jay, did you increase your SPG ?
Old Aug 18, 2022 | 03:45 AM
  #46
jayyyw's Avatar
No, sir. Not yet. I did pull the old plugs out and check the gap, they were at .040". Once I throw a new set in, I'll try .060".
Old Aug 26, 2022 | 10:52 AM
  #47
IGN-1A's Avatar
Default Scott Performance Wire
Many here have asked about Spark Plug Wire.
Mark at Scott Performance Wire stocks/manufactures LS wires for use with the IGN-1A coil.
Old Feb 26, 2023 | 06:40 PM
  #48
Leetron's Avatar
I have supplied the IGN-1A coil for more than twenty years.
I am the one who created that name.
I have offered LS-1Tech members a very good price if asked.
I also supply the LS "sub-harness" for these coils and valve cover brackets.
Is this beneficial to a 800 whp single turbo car?
Old Feb 28, 2023 | 01:57 PM
  #49
IGN-1A's Avatar
Default IGN-1A Users report
Hi All, IGN-1A users report to me, MY 500 HP engine on a RWD made 18 more HP with your coil.
They report better MPG and improved throttle response.
Lance
Old Feb 9, 2024 | 11:37 AM
  #50
pete466ss's Avatar
Lance
Are these IGN-1A coils, sub-harness and valve cover brackets still available? What is the ls1tech member price?
Pete
Old Feb 9, 2024 | 09:36 PM
  #51
jester1's Avatar
Im curious too ^^^
Old Feb 23, 2025 | 12:58 AM
  #52
Gen2-LT4's Avatar
Originally Posted by jester1
Im curious too ^^^
Apparently not...
Lol
Old Feb 23, 2025 | 04:29 PM
  #53
IGN-1A's Avatar
Default Sake Bomb Grauge
Yes, they are, call Heath.
I am not allower to advertise here.
