MAP sensor discrepancies
Old Sep 13, 2022 | 09:44 PM
sewerpickle's Avatar
Default MAP sensor discrepancies
Started making some pulls and datalogging the runs. On the datalog it shows the MAP sensor saw a peak of only 5.1psi around 4,000rpm and held steady all the way to 6,500rpm. My fuel pressure base is 43psi and saw a peak of 59psi. So a total of 16psi increase.
I bench tested the map sensor with regulated shop air. With the sensor plugged in to the holley harness the boost gauge on my dash was spot on with whatever pressure I set the regulator at. The sensor screws directly into the intake. I trying to figure out where or why there is an 11psi difference. I tend to trust the fuel pressure sensor because it needs mechanical force on the diagram before the sensor can read an increase in pressure.
L33 5.3
S488
BOSCH 210's on E85
Holley mid ram intake
Holley terminator x
A2W intercooler
Currently only using spring pressure on twin 38mm gates
1.80 glide, custom PTC converter
Old Sep 14, 2022 | 05:33 AM
Johnny_M's Avatar
I would hook up a mechanical pressure gauge to the the intake and put the gauge where you can see it while making a pull.
It sounds redundant, but it would be a good double check. Eliminating all electrical problems.
Old Sep 14, 2022 | 09:08 PM
Project GatTagO's Avatar
L33 5.3
S488
BOSCH 210's on E85
Holley terminator x
A2W intercooler
Are you sure that the MAP sensor is configured properly in the Sensor ICF? With the engine off, the MAP reading should match the Baro channel within a couple of kPa. If it is more than that, I suspect you have selected the wrong MAP sensor calibration.
Andrew
Old Sep 14, 2022 | 09:23 PM
Andrew
Andrew, thanks for the reply. Can you elaborate a little bit on MAP sensor matching the Baro channel, and sensor ICF, and sensor calibration. I'm still very new with the Holley system but do enjoy learning in baby steps.
Old Sep 14, 2022 | 09:36 PM
Hopefully you're working with a laptop and the USB to CAN cable. When you enable the USB link, you will see live sensor data. In the lower left hand box, toggle to the one that says Sensors. You'll see the MAP channel and also the Baro channel. With the engine off, the MAP and Baro should match within a couple of kPa. If you need help with this and with tuning, shoot me an email: projectgattago at Gmail dot com
Andrew
Old Sep 14, 2022 | 09:43 PM
I do everything with a laptop, in fact I have probably only used the 3.5 screen two times and hated it. I will check those things and report back. The car will somewhat be on the back burner for a bit with fall coming, and as of today trying to close on a house.
Old Sep 14, 2022 | 09:57 PM
If the sensor is not configured correctly would it be displaying incorrectly on my dash? Sensor plugged into harness, then regulated shop air on the map sensor at different pressures, the holley dash was alway within .5psi of the mechanical gauge on the shop air regulator.
Old Sep 16, 2022 | 12:15 PM
rpturbo's Avatar
What map sensor are you using? There is a built in map, so you not only need to make sure your not using that, but need to make sure that you have it configured for the correct sensor you are using, as well as previously said, make sure with key on engine off, it should be right about whatever your normal atmospheric pressure is (not sure where you live)
Old Sep 16, 2022 | 09:32 PM
I'm using a holley sensor. 554-108, I know I don't need a 5 bar sensor, but it came with the terminator kit. I'm in midwestern illinois, about 3hrs north of Alton Il.
Old Sep 17, 2022 | 02:39 AM
QwkTrip's Avatar
Why are you doing MAP in psig instead of absolute pressure?
You set your base fuel pressure at engine idle which was pulling manifold vacuum at the time. +5 psig manifold pressure is a lot more than 5 psi rise from whatever were the vacuum readings at idle.
Also, you're losing sensor resolution by having a MAP sensor with such a large range in excess of your needs. I don't know if it matters though. It does matter that you have the right transfer function from voltage to pressure programmed for the sensor.
Old Sep 17, 2022 | 06:53 PM
rpturbo's Avatar
I don't know how far you plan on turning this up, but I'm doubting you'll need that much MAP.
Sorry if this comes off the wrong way, but I know your username, but can't come up with more. IDK if I've met you or anything else. It's just odd you mentioned Alton, that's where I live. Not a town most people mention is all.
My memory kinda sucks.
Old Sep 17, 2022 | 10:30 PM
The map sensor was a freebie when I purchased the terminator x. If there is too much resolution using it, I will switch to a different one, but I don't think resolution is the issue. I think you were interested in a turbo from me at one point, or you had parts for sale that I was interested in, I'd have to look at my old PMs. I just remember your username and is saying A-town.
Old Sep 18, 2022 | 11:39 AM
rpturbo's Avatar
I figured it was something like that, but didn't know if I had seen your car or did something with the tune. Just trying to make sure. Yeah, this sounds more like a mechanical issue to me, which is why I was asking how the valves were setup ECT.
Old Sep 18, 2022 | 09:34 PM
Still learning the holley system is why it's in PSIG instead of absolute, can you explain the difference? The digital gauge on my holley dash has only gone up to 3psi, so I don't think it's configured correctly yet.
Base fuel was set with engine off, pump running. 43psi.
Old Sep 19, 2022 | 03:21 PM
LSswap's Avatar
I relocated the map remotely from the manifold because I felt I was getting readings affected by the pressure pulses in the manifold. That also allows me to run the same boost feed the the map and the fuel regulator. So while the engine is not running and ignition is on, I can manually pump the feed line with a bicycle pump and check the fuel pressure and map reading with a manual gauge as well as digital. Takes out the guesswork.
