Maxing out LS7 MAF, is there a frequency shifter?
I guess fundamentally, how do 1000hp cars run a MAF? Custom ECU with wider range? Different MAF sensor?
SPEED DENSITY NEED NOT APPLY.
http://www.gmtuners.com/tech/MAF_resistor_mod.htm
May try a frequency divider using a flip flop.
I can appreciate you being stubborn with maf and all that.
things that come to mind are the spacer I mentioned. A bigger intake tube. 5” shouldn’t be too hard to pull off. A ‘calibrated’ air leak post-maf.
a frequency divider sounds tricky to do diy. Back when I played motorcycle there were inline speedo recalibrators for when you change sprocket. Might be worth a look.
How much of an increase in the MAF headroom you looking for?
- MAF translator (yes they still sell these things)
- Just go SD and be done with it and not worry anymore
You go speed density, not sure why you have an aversion to running it in SD as pretty much every higher power car does no matter if it's an OEM computer or standalone. Also the 99+ PCM swap is NOT hard, just a bit time consuming and you can run 3 bar without scaling like you have to do on a 98 PCM in SD.
Have you seen a maf translator that shifts the frequency? All the ones I've seen are for voltage and don't apply to our ECU. Harlan made one, but I dont see them anymore.
I have the GM maf in a 5" tube. I don't use it for anything other than actual airflow data.
But this was right around 11,000hz , fairly decent power, over 200mph in a standing half on the highway.
To give you the idea on range in a 5" duct
