93-97 Turbo'd Trans Am guys
Old Oct 7, 2022 | 02:23 PM
69PrimedC10's Avatar
Default 93-97 Turbo'd Trans Am guys
Ok I'm doing an LS swap on my 93 TA and installing a Huron Speed turbo kit. What have you guys done to the front end to bring in more air for the intercooler? I want to keep use of my fog lights because it is a street car. Thanks
Old Oct 8, 2022 | 01:13 PM
Money_Pit's Avatar
You can find some images of people cutting up the front end of their bumper, some look nicer than others; some just dont run a front bumper. as for the lights... I deleted mine fog lights for functionality and looks ( have the formula front bumper) But you can adjust the headlights to point down more.
Old Oct 8, 2022 | 01:35 PM
Black_Sunshine_99's Avatar
A2W intercooler ftw.
Old Oct 8, 2022 | 01:43 PM
Money_Pit's Avatar
A2W for the street ?
Old Oct 8, 2022 | 02:36 PM
Oh yeah, I run one, works amazing.
Old Oct 8, 2022 | 02:45 PM
Money_Pit's Avatar
If youve got any images, do you think you could send me those, showing how it is set up ? Since Firebirds dont really have a grill, ive always thought that A2W would be a little more worth it in that situation.
Old Oct 10, 2022 | 12:00 PM
Yea I'd like to see them as well. Thanks
Old Oct 10, 2022 | 12:27 PM
The setup is pretty simple, Frozen Boost 2,000HP cooler in the nose right behind the grill, 1 inch lines, aluminum 2-3 gallon tank in the t-top holder with a Rule 2000 pump inside.
Yes you'll spend more than an A2A but your IAT's will be much more controllable, I only run ambient temp water and my temps never get high.
In fact with the oversized cooler, my temps drop when the airflow through the cooler is increased when making a pass.
Old Oct 10, 2022 | 01:07 PM
Whose cage are you running?
Old Oct 10, 2022 | 02:02 PM
Wolfe Racecraft bolt in which I'll be removing for a MWC chassis 8.5 cage at some point.
