Final #'s 1560hp 1186ft lbs
Thanks,
Josh
I anticipate the head gaskets will be holding. I am building a engine for myself that will get more "abuse" to help us find the limits of the gasket.
Kurt
Thanks,
Josh
Final peak tq was 1186@6500 24.6 psi
peak hp was 1560@7000 23.4 psi
Kurt
that is a great feat taking ls1technology to the next level.
most people brag if the achieve half that much power but this is unreal!
Kurt
worked out OK for you ????
Meaux Racing Heads
OK, OK, hand finished by Wheel to Wheel, can I sell you a set too? Or maybe send me your best port and we'll put that in our arsenal of killer ports, and you can give your elbows a break!!
He is a honeslty a great guy. Kurt
He is a honeslty a great guy.Why are they PM'ing you? Why aren't they posting how they feel? I think I know why.
Plain and simple. If you want to make big FI power W2W is the place to go. With that motor making 1500 easy HP. People are going to **** when Kurt is done with his.
He knows what he is doing and it shows...
We used a Cam Motion solid roller.
The intake has 262 duration with .724 lift on a 111.8 centerline.
The ex has 256 duration with .727 lift on 119.8 centerline.
The lobe seperation is 115.8.
The engine comes up on boost smooth and idle's comfortably at 1200 rpm.
Kurt
Phillip
