Finally sharing my build…
Old 08-27-2024 | 12:09 AM
  #121
Pro Stock John's Avatar
LS1Tech Co-Founder
In a word... No. lol
My buddy Kevin was there with his brother's NA 3rd gen (black paint), and they made 3 hits in the car, has a Tommy Martino pro stock style engine in it. They were making the first hits in the car, first was a 200 foot pass to make sure everything was working right, second one they went farther out and third they ran the 1/4. But even with making shock changes it was becoming clear they probably have to add weight to the front end.
The following users liked this post:
C5_Pete (08-27-2024)
Old 08-28-2024 | 11:11 AM
  #122
C5_Pete's Avatar
The following 5 users liked this post by C5_Pete:
brutalzo6 (08-30-2024), gnx7 (09-16-2024), Pro Stock John (08-28-2024), spray280 (08-29-2024), The BallSS (08-28-2024)
Old 08-28-2024 | 05:38 PM
  #123
LS1Tech Co-Founder
Those 275s or 235s Pete?
Old 08-29-2024 | 08:07 AM
  #124
C5_Pete's Avatar
275 Pro Radial
I think I’m gonna try the Pro Bracket Radial, as these tires are 6 years old.
I’d consider a slick, but then I’d need new wheels, as I do not have bead locks on these wheels…
It’s only money, right?
Old 08-29-2024 | 10:43 AM
  #125
NicD's Avatar
7 Second Club
275 PBRs here, ran a 7.75 in my C6Z and a 7.43 in a C7Z on stock style rear suspension. A 4 link setup should have no problem with any tire.
C5_Pete (08-29-2024)
Old 08-29-2024 | 05:25 PM
  #126
LS1Tech Co-Founder
I'd dial the car in on those Pros as long as they aren't dry rotted.
Car looks awesome in the pic, my buddies loved your car at Cecil.
Old 08-29-2024 | 06:04 PM
  #127
C5_Pete's Avatar
Yeh, I’m not buying tires yet.
9/14-15 at Cecil County. There is some sort of event going on the 15th. 1/8th mile N/T NoPrep. Not sure I’m a fan of no prep, but I’m going to see how it is.
Old 08-29-2024 | 09:56 PM
  #128
LS1Tech Co-Founder
Well you can always leave soft and just figure stuff out. My first track pass in the car we had the tune more conservative than what I had on the street... 10.2. Went 9.3 on the 4th hit.
Are you going to the track solo or having a buddy or two watch the car (and film?)
Old 08-31-2024 | 08:46 AM
  #129
C5_Pete's Avatar
Yeh. I’m working with my tuner. Planning on 9/14 to make a few hits and see what happens.
I’ll keep you updated.
Old 09-02-2024 | 01:33 PM
  #130
ls3fox's Avatar
7 Second Club
How'd you make out at yellow bullet and scotty is doing a rental 9-13 @ lebanon they did a really good job prepping it on his last rental
The following 2 users liked this post by ls3fox:
C5_Pete (09-03-2024), Pro Stock John (09-02-2024)
Old 09-03-2024 | 12:09 AM
  #131
C5_Pete's Avatar
With only just one pass that day, I was not comfortable entering any class at YBNats…
In hindsight, that was a Big mistake. I need seat time. I was off work those days… I'm disappointed I didn’t enter and test. My tuner was there. I could have gotten valuable information and data.
so, I went as a spectator on Friday.
I’m planning on going to Cecil County on 9/14 to make some passes and maybe run the event on 9/15.
Nice to hear Scottie has some other events/testing days.
Old 09-07-2024 | 09:42 PM
  #132
C5_Pete's Avatar
Still working on the car when I have time.
Today, worked on the cooling system. It runs really hot. I have the radiator in the back. Had a Meziere pump up front. Now I have a Davis Craig pump screwed right onto the radiator. It’s an Afco 2 pass race radiator. With 2 8” fans mounted to a nice shroud. 16AN hose for the entire system. Still seems to run hot, so I likely still have some air in the system.
Also, did a few other electrical odds and ends. For some reason, my brand new 16v alternator quit working. On the dyno, I was throwing the belt, so I rigged up a new mount for it. While doing so, I dropped it about 12-18” onto the floor. So, not far. I can’t imagine that could have broken it, but it doesn’t work now, so it must have.
damn…
I’m planning to give it another go at Cecil County Saturday 9/14.
The following 3 users liked this post by C5_Pete:
jayyyw (09-11-2024), Keith (09-12-2024), Pro Stock John (09-07-2024)
Old 09-10-2024 | 07:36 AM
  #133
The BallSS's Avatar
damn…
Perhaps there's a local alternator rebuilder who can fix it?
C5_Pete (09-10-2024)
Old 09-10-2024 | 10:10 AM
  #134
LS1Tech Co-Founder
Can you drive and idle the car anywhere by you?
Old 09-10-2024 | 03:37 PM
  #135
C5_Pete's Avatar
Yeh, I do have an alternator specialty shop near me. I’ll give them a call. Thanks for the idea…
I do have a place to drive the car around.
Regardless of my alternator situation, I’m going to Cecil County on Saturday.
Old 09-10-2024 | 10:09 PM
  #136
LS1Tech Co-Founder
How do you burp a rear mounted radiator car?
Good luck this weekend Pete!
Old 09-11-2024 | 11:30 PM
  #137
jayyyw's Avatar
MY rear mounted radiator setup was a little finnicky but I finally got it to work right after burping it a few times. Would keep the car around 160 degrees at idle and highway cruising would be in the 180s. I just used a single davies craig off the radiator as well.
C5_Pete (09-12-2024)
Old 09-12-2024 | 08:49 AM
  #138
C5_Pete's Avatar
Good to know. Did you have a thermostat in the system anywhere?
Old 09-12-2024 | 08:52 AM
  #139
LS1Tech Co-Founder
Since you don't have a heater core Pete wouldn't think you'd need a thermostat.
I have my radiator up front and what I did to burp mine was jack the car up as high as my jack would allow and left it like that overnight. I have an Amazon adaptable funnel I twisted onto the filler spot and then left ~2 pints in the funnel.
Old 09-12-2024 | 09:43 AM
  #140
C5_Pete's Avatar
I’m just wondering that without a thermostat, there would be no restriction and perhaps the water is moving too fast to adequately cool?
I haven’t run it much since my last go around with burping. Hopefully, I finally got it.
Quick Reply: Finally sharing my build…
