Finally sharing my build…
#141
Granted it's not rear mount but it is a dual pass radiator in a stood-up configuration.
It'll idle at 170-175 degrees all day, run down the highway at 2,500 rpm at 190-195 degrees on an 80+ degree day and as soon as I get to the end of the offramp it drops to 180 degrees.
The following users liked this post:
C5_Pete (09-12-2024)
#146
LS1Tech Co-Founder
Aight let's send Pete some positive vibes.
Here are my suggestions (you didn't ask lol but here they are).
- I run 17 psi, Ron Rhodes likes that tire pressure for 275s.
- First hit since you didn't do any street hits, I'd leave on 6 with a 1.5-2.0 second ramp, run 10 - 15 lbs. It will run somewhere in the 10s. It's literally going to drive out on 6 lbs. I added 2 more lbs on the leave and shortened up the ramp a lot (and ran more boost on the next hit, 15 psi) and it still drove out. When I drove my car on the street I was hitting it with 15 psi and I ran about the ET I felt it would run.
- You said a buddy will go with you, it's nice to have him double checking if you are straight because you have a lot going on.
The BallSS (Yesterday)
Pro Stock John (09-13-2024)
#148
John’s good vibes somehow worked…
1 pass two weeks ago - spun
1st pass today - spun
did a little adjusting…
2nd pass today, 3rd on the setup…. Did not spin. Beat John’s ET… by a bunch…
The following 5 users liked this post by C5_Pete:
brutalzo6 (09-14-2024), jayyyw (09-14-2024), ls3fox (09-14-2024), Pro Stock John (09-14-2024), The BallSS (Yesterday)
The following 2 users liked this post by Pro Stock John:
C5_Pete (09-15-2024), The BallSS (Yesterday)
#150
In case you’ve been curious about the ET slip.
Seems to me that there is a lot of potential in this setup…. After all the years it took for me to build this car, I’m finally feeling good.
brutalzo6 (09-15-2024)
#152
Thanks and I’m running a 91/102 from Jose now.
So, naturally I would hope, that a purpose built race car with a bigger turbo would be quicker that a cool street car with a smaller turbo… but we all know that’s not always the case…
The following 2 users liked this post by C5_Pete:
Pro Stock John (Yesterday), The BallSS (Yesterday)
#153
LS1Tech Co-Founder
8.6/6.5 in 3 passes, that's pretty badass, take a minute to pat yourself on the back for all the work you did on the car.
There was a recent thread on FB in Boosted LSX where folks discuss non-intercooled setups, a few folks had been high 4s.
C5_Pete (Yesterday)
