best LS2 fuel injectors
Old Dec 28, 2022 | 08:57 AM
Tabloma's Avatar
Default best LS2 fuel injectors
I am installing a magnuson supercharger on a 2005 Chevy SSR with a 6.0 from the factory. I need 60 lb injectors that I do not have to change the harness plug. I will be tuning with hp tuners stuff. I want really good parts so I dont have issues. I wont be running more than 8lbs of boost and I drive it on the power tour etc.
Thanks
Old Dec 28, 2022 | 09:48 AM
LS1Formulation's Avatar
I'm assuming this supercharger doesn't use stock fuel rails? Is it a kit for the SSR specifically? The factory LS2 injectors should be an EV6 connector, you just have to make sure you have the correct injector length.
Old Dec 28, 2022 | 10:14 PM
Project GatTagO's Avatar
Injector Dynamics has the best high impedance, high flow injectors.
Andrew
Old Dec 29, 2022 | 12:39 AM
LilJayV10's Avatar
Injector Dynamics.
Your definition of "best" might change though when you see their price.
Old Dec 29, 2022 | 06:53 AM
02EBC5Z06's Avatar
As mentioned, ID is a good choice.. Or for a more reasonable offering, look into FID (Fuel Injector Development). Very good quality with great data and about half the cost.
Old Dec 29, 2022 | 10:11 AM
RonSSNova's Avatar
FIC (Fuel Injector Clinic) are also good. Used many sets at the shop, never an issue.
Ron
Old Dec 29, 2022 | 12:24 PM
TheWrathofDan's Avatar
Thanks
if you want 60lb. just buy siemens injectors. you can buy any adapter for injector wiring plug you need
https://www.racetronix.biz/p/injecto...imer-ev1/ia-um
Old Dec 31, 2022 | 07:43 PM
Jimbo1367's Avatar
Deatsch worx injectors are a good option too. They seem to have good results. They’re what I got for my swap. Cheaper than FIC of ID.
I think I paid $518 for 72lbs (@58psi) at Summit Racing
