Turbo silverado
Different gear manufacturers build differently. I would never purposely use a ring gear from one and a pinion gear from another. Although the tooth count can be exactly the same, there are so many differences in the manufacturing process, hardness scale, pitch, ECT they probably won't last, not to mention, getting them setup to spec, would probably be a nightmare.
I've setup hundreds of gearsets. When I did Mustang gears, the ONLY gears I would use in a 8.8 were Motorsport gears from Ford. I knew exactly what I was getting out of the box. I could set those gears up in 2 hours total. Different brands, different story.
I personally think, setting up gears, is the second most time consuming, and critical thing in assembling a item on a car, next to building a transmission.
If you look at most "typical" gearheads, those are the 2 things I'd guess 75-80% of guys just won't do themselves.
Wow thats crazy, idk why they leak like that. Thats what i did too, and I have a cut off already installed, it was there before the turbo.
i have added that to my list of 'worth the extra money' list of parts.
