Boost reference reg in way
Old Aug 15, 2023 | 06:40 AM
mhelmer188's Avatar
Default Boost reference reg in way
Is it possible to rotate the neck in the water pump? My boost reference fuel pressure regulator hits the neck of the water pump.
Old Aug 15, 2023 | 07:26 AM
Black_Sunshine_99's Avatar
Move it to the driver side rail?
That's where mine is.
Old Aug 15, 2023 | 08:02 AM
91 Z28's Avatar
Yep what he said☝☝☝ Driver side rail
Old Aug 15, 2023 | 11:18 AM
mhelmer188's Avatar
it’ll hit back of my alternator. Unless I relocate alternator
Old Aug 15, 2023 | 11:32 AM
91 Z28's Avatar
Try a female 90* coupler off the rail and attach the regulator
Old Aug 15, 2023 | 11:59 AM
GMCGreg's Avatar
Or a 45° tilting the reg up and to the pass side a bit?
Old Aug 15, 2023 | 06:44 PM
jester1's Avatar
I made a small bracket off my DS Valve cover then routed the outlet under the TB and into the rail on the PS. My rails are flipped.
Old Aug 15, 2023 | 08:04 PM
rpturbo's Avatar
Maybe change it so the sensor is facing forward, the front of the passenger rail, 90* into the same current port, and a 180* fitting out of the other port, down below, to driver side.
