How Much Pump Gas Powa???
Old Jul 13, 2023 | 12:26 PM
Black_Sunshine_99's Avatar
Default How Much Pump Gas Powa???
Just wanted to get some opinions on pushing pump 91 fuel only, no meth.
How far have some of you pushed pump gas power/boost wise?
Current combo is as follows running really close to 16 lbs. at the moment with 12 degrees of timing at WOT but wondering if I should keep going and if ice in the A2W would provide the extra cushion needed.
Would it be possible to get up into the 20 lb. range using ice water to keep IAT's low?
What are your guys thoughts?
LS1 / Forged dished piston (9.5:1 ish comp?) H-Beam rod.
CNC Ported 243 heads (might be 317 but I doubt it with the dished piston)
FI Billet S484 T6 w/ 96mm Turbine
Brute Speed FI Cam
Vic Jr. Intake / Aarons Elbow / 105mm TB
2000hp A2W setup (IAT's never get over 100 degrees with ambient temp water even after back to back pulls, haven't tried any ice yet)
TH400 / 3.50 gear / 28 inch tire.
Popular Reply
Jul 13, 2023, 08:26 PM
RonSSNova's Avatar
RonSSNova
Inch the timing up till you drive over the crank, then back it off 2 degrees.
Old Jul 13, 2023 | 01:17 PM
slothman's Avatar
Brute Speed FI Cam
honestly I wouldn't push it with 91 octane....what is your tuner saying? 91 can only go so far, and detonation can destroy **** real quick, even a forged setup.
do you have e85 in your city ? if you do, that is hands down the best route. Of course then you are ******* with bigger fuel injectors and that whole bit.
if you want more power I'd throw on a 100 wet shot. cheap, more power, and significantly cools down the combustion chamber and IATs.
Old Jul 13, 2023 | 02:12 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
*cracks knuckles"
Only one way to find out....
Old Jul 13, 2023 | 02:43 PM
NicD's Avatar
7 Second Club
Never would I suggest going up from 16 psi on pump gas as that seems a bit high to me already.
A 100 shot is NOT going to cool down the combustion chamber and will have virtually no affect on IATs.
Old Jul 13, 2023 | 04:38 PM
ddnspider's Avatar
I'd totally be running a $300 WMI kit for that boost on that setup, especially with 91 octane. I'm doing it on 93, but at a point higher compression, but a smaller turbo. Playing with fire right now. What does the plugs say?
Old Jul 13, 2023 | 05:52 PM
Shownomercy's Avatar
Man-Crush Warning
93 octane here, no W/M, car weighs around 3500lb and traps 140
Old Jul 13, 2023 | 07:41 PM
This is what I was basing my hopes on, 16 lbs. was the max limit I was really intending to run, anything higher and I was gonna do a pump gas/methanol mix.
I've talked to a few other guys running 18-20 lbs. on pump but I get every combo is different.
@ddnspider haven't checked any plugs up to this point because honestly, I don't know how to read them anyways.
Not seeing any knock and IAT's are really low so I thought that might give me a little more space as opposed to an A2A IC.
I've told my tuner my intentions and he hasn't come right out and said don't do that lol.
Old Jul 13, 2023 | 07:56 PM
slothman's Avatar
could you please elaborate? that goes against everything I have ever read and heard from others lol.
EDIT: sorry, I was wrong and confusing it with methanol
Old Jul 13, 2023 | 08:06 PM
slothman's Avatar
other guys running 18-20 lbs..
even 18 pounds on 93 is cutting it close. 18 pounds on 91 isn't a good idea. IMO 14-16 pounds on 91 is about the limit. the risk of detonation isn't worth it. Either go meth or E85. JMO of course
Old Jul 13, 2023 | 08:26 PM
RonSSNova's Avatar
Old Jul 13, 2023 | 08:39 PM
NicD's Avatar
7 Second Club
Yeah every combo is different which is why I really don't like that picture. I can say that most of the 9.0 - 9.5 compression combos that I see with average sized cams and "street sized" turbos wouldn't even make it to 15 psi on 91 octane out here in AZ with our temps, etc. Now I'm referring to guys who are actually out beating on it making full 1/4 mile pulls and not just driving it around on the street and making little hits here and there. Hell even most LSA/LS9 combos with their soft chamber heads and restriction free exhaust (which are easier to get timing in to than most turbo setups) are headed towards the single digits for timing at 15 psi on 91 oct here, and single digits starts to spell disaster as you are really starting to exceed what your fuel is capable of and it produces a crappy burn. Again, there are so many differences in combos that it's impossible to say what it would take exactly...
Old Jul 13, 2023 | 09:03 PM
So right now its making 15.3 lbs. according to my last log.
Thinking I'll just leave it there, start mixing up some pump/meth and go from there.
Right now, just going off logs and knock (I know, I know), I'm not checking plugs because being totally honest, I don't know how.
I've watched videos of guys explaining it and I just don't see what they see, might be my partial color blindness.
E85 isn't an option, gonna leave it and mix some high test.
Old Jul 13, 2023 | 09:15 PM
That's horrible advice Ron lol.
Old Jul 13, 2023 | 09:29 PM
slothman's Avatar
if the car is only driven on weekends etc, you could try boostane or torco octane booster. One can will bump you up to about 96-97 octane. If you keep the timing where it is now, you could up the boost a couple of pounds safely. plugs are also a big factor, you want to be running 2 steps colder with that much boost (you didn't mention which ones).
Old Jul 13, 2023 | 10:21 PM
It's strictly a street car but I make pulls from 40mph up to 150mph so might as well be 1/4 mile.
I'm gonna buy some methanol and mix it 50/50 with pump gas and run that with some ice in the cooler.
Plugs iirc are BR7EF's I think
Old Jul 14, 2023 | 06:23 AM
ddnspider's Avatar
Get some close up pics of the porcelain and ground strap and post them here.
Old Jul 14, 2023 | 07:11 AM
Old Buzzard's Avatar
"I'm not checking plugs because being totally honest, I don't know how."
Start by looking to see if any of the plug electrodes are missing....
Or educate yourself.
Here's enough to keep you busy for a while.
​​​​​​​how to read spark plugs for tuning - Search (bing.com)
Old Jul 14, 2023 | 10:07 AM
Thank you Captain Obvious, I already explained that I had tried learning but was having difficulty seeing what was being discussed.
Old Jul 14, 2023 | 10:08 AM
Will do, don't they need to be new plugs though?
I've been running on these ones all summer thus far.
Old Jul 14, 2023 | 04:47 PM
ddnspider's Avatar
Everyone says that, and I'm sure there are instances where it's true like running straight methanol, and maybe nitrous. I call BS on real street pump gas stuff. You can't tell the fueling, but you CAN tell the timing, heat range, and signs of detonation or speckling. I don't care if the plug has 1000 miles on it you can still tell that stuff.
