Popped head gasket
Old Sep 24, 2023 | 09:59 PM
sewerpickle's Avatar
Default Popped head gasket
Buddies car, looking for opinions on a possible cause. Iron 6.0, summit pro rod/piston. TFS heads, BTR stage 3 turbo cam, ls9 head gaskets, copper sprayed, 88mm turbo, on E85. Made a handful of passes on 23psi. Last pass, car died going through the traps.
Old Sep 24, 2023 | 10:22 PM
Is the block half-filled?
Old Sep 24, 2023 | 10:39 PM
Block is not filled.
Old Sep 24, 2023 | 11:58 PM
djones293's Avatar
I would get the injectors flowed. It’s possible that it leaned out on that cylinder.
Old Sep 25, 2023 | 09:37 AM
Old Buzzard's Avatar
Plugs look like??
Old Sep 25, 2023 | 12:39 PM
Originally Posted by Old Buzzard
Plugs look like??
Garbage, lol
Old Sep 25, 2023 | 01:34 PM
Damn!
Is that #6 with the rust on it?
Torch the head and/or the block?
In any case, one sick puppy!
Old Sep 25, 2023 | 02:51 PM
Torched the head on #5, I don't think he's pulled the other head as of yet.
Old Sep 25, 2023 | 04:45 PM
GMCGreg's Avatar
Is that a cracked porcelain on the plug opposite the one indicated by the arrow?
Old Sep 25, 2023 | 04:53 PM
Good eye, that's what I thought too. My buddy said it was just a piece of debris and not a crack.
Old Sep 25, 2023 | 04:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Holley? What did the log show?
Old Sep 25, 2023 | 04:57 PM
Yes, they are using holley terminator, but for some reason they were not datalogging any runs throughout the night. I have no idea why. I told him without logs, it's going to be a guessing game until it let's go, and here we are.
Old Sep 25, 2023 | 06:00 PM
LS1Tech Co-Founder
What's the fuel system? Looks like it ran lean?
Old Sep 25, 2023 | 06:13 PM
GMCGreg's Avatar
Thinking the same, looking like it went lean - at least on that cyl
Old Sep 25, 2023 | 07:04 PM
RonSSNova's Avatar
Be curious what timing and AFR. 23 psi should be no issue if the tune is correct. We run that and more in my buddies 6.0
We don’t spray the gaskets.
Old Sep 25, 2023 | 08:00 PM
Fuel system would be solid but the electrical side is questionable at best, so there's that. I built the engine, guy wanted the gaskets copper sprayed, I told him it would hold no better sprayed than not, but it's not my engine.
Old Sep 26, 2023 | 09:03 AM
Project GatTagO's Avatar
There might be clues in the tune that is on the ECU. Have your buddy extract the tune that is saved on the Terminator X right now and post it.
Andrew
Old Sep 28, 2023 | 06:26 PM
rpturbo's Avatar
Andrew
Exactly, if they pull the tune and the learn table added a bunch of fuel, well at least they know "that" much. Unless the learn was gutted too, to go along with no data log.
Old Sep 29, 2023 | 07:50 AM
slowride's Avatar
Everybody loves that copper spray I know customer wanted it done, but it only helps seal water leaks on poor surfaces not like it can help with actual combustion pressure. How were the overall surfaces of block/head to start out?
Old Oct 11, 2023 | 06:52 PM
rpturbo's Avatar
Sewerpickle, you come up with anymore? I will say, I'm glad I'm not the only one who tunes for people who can't even click the log button. 😂
