Projected horsepower
Old Oct 22, 2023 | 05:35 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Burning plug wires is sort of an initiation into aftermarket turbo systems, lol. There is always an unexpected extra heat shield or wire sleeve needed somewhere. The best way to tell if you would be able to learn tuning on your own would probably involve downloading the HPtuners software and looking at the many youtube videos they have on how to use it. If you have a good basic understanding of air/fuel ratios and how engines work in general you should have no problem. Even though there are hundreds of parameters that can be adjusted, only a few of them will be relevant to merely turning up the boost or making minor hardware changes. Just remember that full tuning capabilities also allow you to fully fubar things if you aren't careful.
Old Oct 22, 2023 | 07:08 PM
Tommy42088's Avatar
so I've heard, I wrapped the manifolds and the wires had the fiberglass sleeves on them as well so i didnt expect that to happen. Im sure he will figure that out, that's the kind of reasons I need to learn to tune tho because I wouldn't have been able to tell where the misfire was coming from if I experienced that and also I take the truck to the track pretty often so being able to at least turn it up at the track would be nice. I just don't understand how to actually do that if the maf is actually maxed out.
Old Oct 22, 2023 | 10:56 PM
gametech's Avatar
Your tuning options depends on what PCM your truck uses. I did not see what year on this or your other post. I may have overlooked it. The different computers all have different limits that you may or may not hit, as well as different custom operating systems available through HPtuners and EFIlive. The P01 and P59 computers also have some freeware options, but that is a whole different level of less user friendly learning curve. Also, wrong changes to engine tuning can have transmission implications that can bite you in the ***.
Old Oct 23, 2023 | 05:19 AM
Tommy42088's Avatar
it's a 2000 silverado, single cab. It has a e39 ecu and thats what i was stating in the previous post that the computer was maxed out but I wasnt aware that there is ways around it. My shift points and things with the transmission I wouldn't want to change. Im going to 7k.
Old Oct 23, 2023 | 05:21 AM
Tommy42088's Avatar
Old Oct 23, 2023 | 08:30 AM
Forcefed86's Avatar
Most tuners wouldn't tell you you can't turn your car up because the maf is maxed is all I was saying. Esp. if you have already got the MAP on there. Calibrate for a 3 bar map and go to town.
Cast OEM manifolds are best by far because you don't' have to worry about plug wires or cracking. What manifolds do you have? You can dent the crap out of the tubular ones with little to no affect on power. But most are trying to run the plug boot in the wrong spot. Re route them to the bottom. I have the typical cheap manifolds used and I've never burnt a plug with this routing and 90* boots.
Billet ICT sells long plug wire relocation kits that work great.
Old Oct 23, 2023 | 08:48 AM
Tommy42088's Avatar
Most tuners wouldn't tell you you can't turn your car up because the maf is maxed is all I was saying. Esp. if you have already got the MAP on there. Calibrate doe a 3 bar map and go to town.
sounds easy for you but for me I wouldn't know where to begin. When I get it back from him I'll buy hp tuners and put a future post with the tune file on it and see if you guys can walk me through it. Last I spoke with him that's what he said he was going to try and do, route under the manifold. That was about a week ago so I'm expecting some kind of update soon. It's a cx racing manifold. I believe you posted in another thread where I had posted a picture of it and I believe you told me to change the air filter
Old Oct 23, 2023 | 09:38 AM
Forcefed86's Avatar
That's the thing though. If he is a tuner, it should be easy for him as well. 3 bar Senor is one bolt and easily accessed. All the changes are in software. It takes no more time to calibrate for that than anything else. Hell, you could bolt the sensor on yourself and send your ecu out for a mail in ecu flash. Had a few friends do this and it worked surprisingly well. Its just odd you have someone saying they can't run more boost because a sensor is maxed.
May have, those filters are usually pretty darn bad. OK to filter dirt for no boost street duty, but could cause a lot of power loss. I couldn't make over 9lbs with mine installed, which looked similar. But may not have been the same brand/quality. pleated filters generally have a ton more surface area is all. I know not everyone can fit a massive filter.
Old Oct 23, 2023 | 10:02 AM
Tommy42088's Avatar
the 3 bar is already installed, I did all the manual work before I dropped it off, all he was supposed to do was tune it but he ran into an issue where he had to tap a line into the turbo housing or something like that and the issues with the wires came up. If it's something I can do myself then I'd rather learn and do myself. I'll try and call him later today and mention what you guys told me ND see what he has to say. There isn't very many tuners in my part of town so we're pretty limited and I can't fit a bigger air filter on it. That one there barely fit. I guess I could buy one of the ones that's basically a screen over the turbo or something similar to that
Old Oct 23, 2023 | 10:12 AM
Forcefed86's Avatar
If its at the dyno have him run it with and without the filter. See if it makes a difference. If its gonna see much street time I wouldn't run a screen. Street cars should have a filter. There are a few low profile pleated filters around that will likely flow 3x what that foam one does.
Yea somethings odd there... I'd tell him to disable the MAF and run a speed density tune. You can remove the MAF later when you have the time.
Old Oct 23, 2023 | 10:27 AM
Tommy42088's Avatar
yes its at the dyno now, I'll definitely tell him that. i drive the truck on the streets occasionally on the weekends and ill take it to the track when i get it back just to see where it stands with all the new parts.
Old Oct 23, 2023 | 04:03 PM
  #32
Tommy42088's Avatar
So he's telling me the manifold I have on the truck isn't going to work. He said it's burning the boots and cracking the plugs every time he goes to make a pull. Basically that I need to put a different manifold on the truck. What do you guys think about that? I just don't understand that man, how can it be getting that hot that it's causing that.
Old Oct 23, 2023 | 05:18 PM
  #33
Jimbo1367's Avatar
Originally Posted by gsteele
math is hard.
lol. Tff
Old Oct 23, 2023 | 05:22 PM
  #34
Tommy42088's Avatar
Really frustrating, idk what to do man. Do I have to pull this kit off and completely start over or is there something he is missing. I just don't understand how a manifold can get so hot that it cracks a spark plug
Old Oct 23, 2023 | 09:42 PM
  #35
Project GatTagO's Avatar
Ten bucks says he doesn't have any timing in it (maybe he doesn't know what he is doing) and that is sending the EGT through the roof.
Andrew
Old Oct 24, 2023 | 10:39 AM
  #36
Forcefed86's Avatar
Have any close ups of the manifold installed without the wires so we can see what the clearance is? Or link to the manifolds with pictures of them installed something else?
There is usually a way around it with a 90* boot and long wires. If there isn’t ¼ or so air gap all around, then clearance needs to be made. You can dent the crap out of the manifold with little to no performance loss. Just heat it up with a torch and use a long pry bar to clearance where needed. Some of the china manifolds are also crazy thin so the radiant heat can be pretty excessive. But if you have a decent air gap it shouldn’t be melting anything. Def. don't need to start over.
Also a chance your timing isn’t synced properly and the motors excessively retarded timing wise. That will cause the manifolds are glow excessively hot. Could be a dozen things… hard to know without being there. either way heat won't cause a plug to crack. It was cracked on installation or prior to install.
Sounds like the guy doesn’t want your money. I’d go somewhere else.
Old Oct 24, 2023 | 10:46 AM
  #37
Tommy42088's Avatar
I can't open these files but Maybe you can, this is suppose to be the tune files. Man I went back and forth all morning and he swears its the manifolds, he said its only happening on number 7&4 and that if it had half an inch more that it would of probably been ok. He says the flanges are welded to close to the 90s. Everyone I've talked to tell me differently but I'm now stuck with a Truck I have to tow home and a 3000 dollar bill
File Type: hpt
File Type: hpl
Old Oct 24, 2023 | 10:48 AM
  #38
Tommy42088's Avatar
This is images from there website but it's the same kit that I ordered
Old Oct 24, 2023 | 11:07 AM
  #39
Black_Sunshine_99's Avatar
7 & 4 are on opposite sides of the engine.
I wouldn't expect any issues from the driverside, just the passenger side.
Get some good ceramic wires like the Accel units and some heat sleeves and start there, make sure the manifold is well wrapped and hell you may need to wrap it twice.
Maybe buy a custom wire set and run them to the rear of the engine and the down around the back of the engine and back up to the front from underneath.
That would keep the wires away from any close heat sources and be pretty cheap and easy to do.
Old Oct 24, 2023 | 11:25 AM
  #40
Forcefed86's Avatar
Remove the problem plugs. Then get a map gas torch and a crowbar. Go to town on the area that needs more clearance. A ¼ gap all around is all that’s needed. Heat sleeves and wrap work great, but you still need a 1/4“ gap at minimum IMO. If the boot touchs the manifold, they will burn up. I’d assume tight 90’s pointing down are what you will need. That does look like a tricky manifold though!. You can also use a metal coat hangar fixed to the wire to ensure it goes where you need it and stays there.
Wouldn’t be able to tell anything from his tune files. It’s the mechanical timing between where the engine actually is VS where the ECU thinks it is. Would need a piston stop to find TDC. Mark the balancer. Then use an adjustable timing light to see where the time actually VS what the ECU is commanding. I’ve had motors be as much as 12* off. So when the ECU is commanding say 15* its actually at 3*. But since you are using the OEM ECU, thats likely not your issue. I’d try clearance first.
