Projected horsepower
Wouldn’t be able to tell anything from his tune files. It’s the mechanical timing between where the engine actually is VS where the ECU thinks it is. Would need a piston stop to find TDC. Mark the balancer. Then use an adjustable timing light to see where the time actually VS what the ECU is commanding. I’ve had motors be as much as 12* off. So when the ECU is commanding say 15* its actually at 3*. But since you are using the OEM ECU, thats likely not your issue. I’d try clearance first.
The fact that both the drivers and passenger side are causing problems is a little suspicious. Is the plug clearance tight on the driver's side?
If the driver's side use a stock exhaust manifold, then the plugs wires should have plenty of clearance.
I can't view the tune, but I'm really curious what the timing was during the pulls.
Andrew
When I did my first turbo build I spent the next year finding all the little issues that come with it, pipe fitment problems, burnt wires, blown fuses, insufficient alternators, insufficient fans, etc.
Just keep chipping away at it and soon you'll have a fun, dependable turbo truck that you can enjoy.
Andrew
Drivers side design
