Projected horsepower
Old Dec 8, 2023 | 06:42 PM
  #241
Full Power's Avatar
Pull spark plugs: see if it will turn over. Report whether or not COOLANT issues from open spark plug holes..... Or FUEL....
Old Dec 8, 2023 | 07:08 PM
  #242
Tommy42088's Avatar
my Buddy just told me the same thing, i plan on doing that first thing in the morning. He said it may have hydro locked?
Old Dec 8, 2023 | 11:57 PM
  #243
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you are lucky it is a stuck open injector that let fuel lock up a cylinder, and the starter did not have enough power to damage any hard parts. Otherwise???
Old Dec 9, 2023 | 08:38 AM
  #244
Tommy42088's Avatar
that's what my buddy said, I'm about to start now, I'll update soon
Old Dec 9, 2023 | 10:25 AM
  #245
C5_Pete's Avatar
Damn…. Good luck with it!
Old Dec 9, 2023 | 11:44 AM
  #246
Tommy42088's Avatar
explains why it wouldn't turn over, damn thats a stab in the gut
Old Dec 9, 2023 | 11:57 AM
  #247
GMCGreg's Avatar
Man , you can't get a break. What got in there?
Old Dec 9, 2023 | 11:59 AM
  #248
GMCGreg's Avatar
That piston looks a little high , something go I the bottom end?
Old Dec 9, 2023 | 12:00 PM
  #249
Tommy42088's Avatar
I don't see anything inside, just a broken rod
Old Dec 9, 2023 | 12:06 PM
  #250
GMCGreg's Avatar
Broken at the oil ring , odd . Other lands intact? Haven't seen 1 Broken like that before
Old Dec 9, 2023 | 12:10 PM
  #251
C5_Pete's Avatar
Man, that sucks…
Old Dec 9, 2023 | 12:22 PM
  #252
Tommy42088's Avatar
everything else seems to be fine, the sleeve doesnt looked damaged thankfully, hard to see in picture but piston is cracking in half
Old Dec 9, 2023 | 12:23 PM
  #253
Tommy42088's Avatar
Originally Posted by C5_Pete
Man, that sucks…
definitely, I have done so much work on this truck
Old Dec 9, 2023 | 05:47 PM
  #254
Tommy42088's Avatar
Old Dec 9, 2023 | 06:47 PM
  #255
GMCGreg's Avatar
Looks like this BBC i just had in my shop , don't even know how it happened, i didn't build it.
Old Dec 9, 2023 | 06:50 PM
  #256
GMCGreg's Avatar
What's the plan? Find another SBE , swap cam and springs and put it in ?
Old Dec 10, 2023 | 09:03 AM
  #257
C5_Pete's Avatar
Dingleberry hone, drop in another rod/piston and run it…
Old Dec 10, 2023 | 11:06 AM
  #258
Tommy42088's Avatar
this is the plan, there's no damage to the sleeve, head needs repaired also. Valve doesn't seal
Old Dec 10, 2023 | 11:07 AM
  #259
Tommy42088's Avatar
wow looks very similar, idk the cause either
did you ever figure out the cause?
Old Dec 11, 2023 | 01:04 AM
  #260
Dian's Avatar
Originally Posted by Tommy42088
A little update, things didn't work out to great, the motor locked up on me. Tried turning the crane with a ratchet and it doesn't budge. Weird thing it was running perfectly fine, didn't do any hard pulls or anything. Did a few text drives and then went at a later date and attempted to crank it and it just clicked like the battery was dead and low and behold the motor now doesn't spin. This truck has gotten the best of me
so engine didt turn at all and no fluid in there?
the piston cant have desintegrated after you shut off the engine, right?
