Projected horsepower
Old Jan 29, 2024 | 12:09 PM
  #441
Tommy42088's Avatar
I've heard a couple times that when you get into higher hp deals with the lockup, it can be hard on parts and high HP is subjective depending on who you ask.
Don't know how true that is since most everyone I know runs PG/400 stuff.
If that's what they recommend, that's what I'd do.
Circle D told me that converter is rated to 800+ hp but they have quite a few people running it beyond that including me so for the price its not a bad deal.
He asked for a full parts list of what was on the truck and after i gave him all the specs and told him my power level on its greatest day would probably be in the 700 range and he right away told me that converter.
Old Jan 29, 2024 | 12:14 PM
  #442
Tommy42088's Avatar
I've got a buddy in Montana that has a fresh built 4L80 for sale that would be perfect for you.
Not a crazy expensive build, he was targeting 800-900hp with his supercharged truck but changed direction on the build.
whats he asking for it?
Old Jan 29, 2024 | 01:31 PM
  #443
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What about Justin Covington with Asylum Motorsports doesn't he does transmissions?
Old Jan 29, 2024 | 01:36 PM
  #444
Tommy42088's Avatar
There a little out my price range
Old Jan 29, 2024 | 01:40 PM
  #445
Tommy42088's Avatar
I really don't need a transmission that is built because I have a local guy that will build an 80e for me for around 1500 and the transmission I'm finding on ebay around 700-1000 so im looking at around 2500 total investment if I go that route and the converter is 1400.
Old Jan 29, 2024 | 01:58 PM
  #446
Black_Sunshine_99's Avatar
This one isn't a crazy, over the top, high dollar build because it wasn't necessary.
High perf clutches, valve body pressure mods, HD Drum, 34 Element sprag the usual stuff, built by a local guy who's been doing it for 40 years and does all my stuff.
He actually bought it already built but had my guy look at it just in case and found it was all messed up.
He wasn't going to race with it, just a fun mid-HP street truck.
I'll ask my buddy and see if he wants to unload it.
Old Jan 29, 2024 | 02:03 PM
  #447
ddnspider's Avatar
Does it truly spool to 3000 or are you holding it from spinning tires at that point?
it's definitely tight which is what I wanted for my setup. Towing and part throttle was important to me. The 7665 spools instantly on my 4.8 and still roasts 31 off road tires from a 35 roll.
Old Jan 29, 2024 | 02:37 PM
  #448
Tommy42088's Avatar
10-4 let me know what he wants to do, I'll hold off on buying something for now. I feel like i need to way my options b4 i jump the gun and get something ill regret.
Old Jan 29, 2024 | 02:38 PM
  #449
Tommy42088's Avatar
yeh I definitely don't want something to tight. I dont do any towing with my truck so thats not a need for me. Street and occasionally strip is the way im looking to go. Need that 10 second pass
Old Jan 29, 2024 | 03:34 PM
  #450
This goes against what I'm saying but I'll never buy a transmission from someone over the internet, I'll always have it built locally.
There's too much inside for someone to screw up and you won't until you put it in the car.
My buddy with the 4l80 thought his was good to go, I talked him into letting my guy open it up and go through it and he's glad he did.
There was cut seals that wouldn't hold air, dry clutches, nothing was lubed/oiled, actual debris dirt/dust in the pan and inside the case and other things that indicated it was thrown together poorly.
My guy said it probably wouldn't even had gone in gear and with the HP planned would've broken in short order.
Sourcing the parts yourself can save money too, the 4L80 uses a lot of TH400 parts which you can collect slowly and then find a good deal on a core unit to build.
Unfortunately, anything that has 4L80 on it is an arm and leg these days because they're so popular.
Old Jan 29, 2024 | 03:58 PM
  #451
GMCGreg's Avatar
Best way I know of to geta 4l80e is to buy a 2500 or 3500 express or savana , most pickups are 4x4 and not what you need. Bonus is maybe a spare engine out of the deal , definitely a lot more work though. As far as a converter goes a triple disc is not necessary and adds some cost - I'm cheap so went single which just means no WOT lockup. The 4l80 has a taller first gear 2.42 vs 3.06 or close to that so keep that in mind when choosing the converter. Depending on your definition of a street truck or daily driver you may not want the stall speed too high and if traction is an issue a higher stall isn't going to do a bit of good . I would not gain anything from a higher stall on my truck with the current suspension
Old Jan 29, 2024 | 04:07 PM
  #452
Tommy42088's Avatar
yeh I just don't like the idea of my truck sitting for too long. Specially with e85 in the tank. I've seen people push stock 4l80e to pretty high extremes and they hold up. It's almost tempting to just put a stock 80 in it and see what happens but then again like you say you don't know what your buying. I may get something and it end up having 250k miles on it and I don't know how well that will do once it sees any kind of power.
Old Jan 29, 2024 | 04:34 PM
  #453
Tommy42088's Avatar
yeh I didn't really understand why I needed a triple disk, i was just listening to the guy at circle d because he knows his product much better then i do and ive been searching all day trying to find one. Ive found a few pull outs on ebay for around 1000$. What did you do to your 80 before installing it or did you install the stock 80? And I Definitely drive it on the street but it's not my daily. I have another truck that I drive daily. Also I want something that stalls enough to get this turbo going when I take this thing to the track .
Old Jan 29, 2024 | 05:10 PM
  #454
GMCGreg's Avatar
I did the transgo hd2 kit to the 4l80 before I installed it . Used the sloppy video as a guide. Worked fine but decided to have it gone over when I broke the diff and driveshaft - as a precaution. A triple disc will certainly work and even help with a couple mph on the top end but an unnecessary expense at this level IMO.
Old Jan 29, 2024 | 05:11 PM
  #455
LS1Tech Co-Founder
Yeah with the 2.xx first gear you'll be able to leave on more boost (and will need to).
Old Jan 29, 2024 | 07:10 PM
  #456
Tommy42088's Avatar
I'm still a little undecided though because I could go the 80e option or I could just get frank to build me a 60e and just send my converter off to pct to get re worked and that may actually be the cheaper and easier route.
Old Jan 29, 2024 | 08:42 PM
  #457
LS1Tech Co-Founder
If you plan to beat on it a lot and make a lot of passes over the next couple of years, you wouldn't find me suggesting rebuilding that 4L60E. On the other hand if your buddy rebuilds it for small money I'd maybe do that just for now.
Old Jan 30, 2024 | 05:17 AM
  #458
Tommy42088's Avatar
that's what a few of my buddies are telling me too thats why im kind of nervous about doing that. I will beat on it a little bit at the track.
Old Jan 30, 2024 | 09:35 AM
  #459
GMCGreg's Avatar
If it's not going to see a lot of highway time a th400 may be an option, not sure how the $$ compare these days though
Old Jan 30, 2024 | 10:41 AM
  #460
Building a TH400 is significantly cheaper, I looked at doing a 4L80 when my TH400 failed and it was about half to have my TH400 built to handle 1,200HP and that was me buying a TH475 core to use.
