Projected horsepower
Old Apr 25, 2024 | 05:22 PM
  #641
Project GatTagO's Avatar
Originally Posted by Tommy42088
Holley came in today, that was fast! Just waiting on the integration harness and I also ordered the bracket that allows me to put the screen in the air bag spot next to the air conditioning controls do I'm waiting on that as well.
About time. If you need assistance with the tuning, keep me in mind.
Andrew
Old Apr 25, 2024 | 05:32 PM
  #642
Tommy42088's Avatar
Andrew
lol, I guess we live and learn, and thanks man. I'll post the tune and dyno numbers when I get it back and see what you guys think
Old Apr 27, 2024 | 05:46 PM
  #643
Tommy42088's Avatar
Just waiting on the integrated harness, ordered it from current performance. They seem to have good reviews and my tuner uses them as well. Hopefully shipment time isn't to far out. I think it's build to order tho so it may take a little time.
Old May 9, 2024 | 05:12 PM
  #644
Tommy42088's Avatar
Do you guys know if anyone else makes the integrated harnesses and keeps it in stock? My estimated shipment date is 7/1/24 , that seems a bit long on. I ordered it 4/22/24
Old May 10, 2024 | 12:56 PM
  #645
Quito195's Avatar
I don’t have a referral, but I will vouch that CPW is worth the wait. Always been very happy with their stuff even with lead time.
Old May 10, 2024 | 12:59 PM
  #646
Tommy42088's Avatar
yeh that's what my tuner is telling me too, just makes me nervous letting my truck sit like that with e85 in the tank. It already sat a little while when I had to put a transmission in it.
Old May 10, 2024 | 02:30 PM
  #647
Black_Sunshine_99's Avatar
Toss a jug of Sta-Bil fuel additive in while its in storage?
Old May 10, 2024 | 03:21 PM
  #648
Tommy42088's Avatar
ah ok, I'll definitely do that. Should I be concerned with the injectors?
Old May 10, 2024 | 05:02 PM
  #649
I'm not super familiar with E85 and its life span while stored but if the truck doesn't run, maybe pull out the injectors and have an injector shop just run them to get the fuel out.
If they get gummy they'll cause other issues and then you'll have to get them cleaned.
Hopefully someone with more experience will chime in.
Old May 10, 2024 | 05:17 PM
  #650
GMCGreg's Avatar
They make a marine version too, specifically says it's made to deal with the ethanol , don't know how good it works but it may help
Old May 10, 2024 | 05:48 PM
  #651
Tommy42088's Avatar
yeh that was my concern, It sat almost 2 months with the transmission, I did crank it a few times but couldn't run out the fuel as it wasn't driveable and now I have to wait until 7/1/24 to even get the integrated harness much less get it put together. Probably closer to August if im being realistic
Old May 10, 2024 | 05:49 PM
  #652
Tommy42088's Avatar
I'll definitely check that out, appreciate the help
Old May 10, 2024 | 06:04 PM
  #653
GMCGreg's Avatar
Is the truck running now ? Hopefully it is cause you'll want to run it after adding stabilizer or else it won't get to the pump , filter and injectors unless you run it
Old May 10, 2024 | 08:44 PM
  #654
Tommy42088's Avatar
Ill have to check with my tuner, I believe he put the original ecu back in it so he could put it inside his shop, if so then yes
Old May 13, 2024 | 02:01 PM
  #655
There you go, toss some Sta-Bil in it, shake the bed really good and let it idle for a while.
Old May 24, 2024 | 05:02 PM
  #656
Tommy42088's Avatar
Current Performance sent me a tracking number this morning, looks like I'll be receiving the integrated harness much sooner then the projected July date! Can't wait, ready for this thing to be complete
Old May 31, 2024 | 04:17 PM
  #657
Tommy42088's Avatar
Update, were running on holley!! Should get it on the dyno tomorrow, we had a rain today and had to move some wiring around on the second fuel pump because it wasn't wanting to come on but we're getting close.
Old Jun 11, 2024 | 09:16 AM
  #658
Tommy42088's Avatar
15 psi, 95% duty cycle on e85, i guess the 2 aeromotive 340's and the FIC 80's are maxed out
Old Jun 11, 2024 | 09:47 AM
  #659
TrendSetter's Avatar
whats the combo
Old Jun 11, 2024 | 10:01 AM
  #660
Tommy42088's Avatar
Originally Posted by TrendSetter
whats the combo
gen 3 sbe 5.3, 243 heads port polished & milled 40 thousands, btr stage 3 truck cam with dual 660 springs. Vsr 78/75 billet g 2.5 series with 1.25 ar, sheet metal intake with 102mm throttle body, Frank built my 4l60e, circle d 258mm 3800 converter, 342 gears with mini spool, dual aeromotive 340 pumps with fic 80lb injectors and we just put holley terminator x max.
this is the same single cab truck you guys had been giving me advice on.
