Need 2/10ths
Old Nov 2, 2023 | 05:33 PM
Boosted_Dreams's Avatar
Default Need 2/10ths
I have a full weight manual 72 chevelle 370ci ported heads, johnson link bar lifters, headers 3in with xpipe, ls6 intake stock TB, vortech v-3 si 3.4 griptech pulley 9-10lbs at the top using air to water intercooler. 275/50r15 d.r. adjustable coilovers. Best time so far was a 3k launch to get 12.10e.t. @ 111.98 . What would be the best purchase to to help get me to 11.99 just to say I did it!
Old Nov 2, 2023 | 06:05 PM
Y2K_Frenzy's Avatar
Would something like a pair of Hooiser QTP’s or something similar be better than a drag radial?
TrendSetter's Avatar
What’s your 60’ ?
and tell us about your tune
Old Nov 2, 2023 | 06:17 PM
ddnspider's Avatar
Agree on what's the 60ft? You need to leave in boost. What are you shifting at and what cam and was it degree'd? What compression ratio? You're missing at least 10 mph if that engine setup is healthy. Did you dyno it?
Old Nov 2, 2023 | 06:40 PM
Shifting around 6500 and a jam cam was the recommended. Not sure about the tune someone did it for me. Had initial problems with belt slippage and a lack of intercooler which has been fixed but never went back to know what the final info was.
Old Nov 2, 2023 | 07:14 PM
You got a lot in that 60’. Practice launching. You should get your 2/10s without having to spend money.
Old Nov 2, 2023 | 07:22 PM
ddnspider's Avatar
Even with a 1.8 that thing should MPH much higher. It's a sub 4k lb car. Is anything being logged?
Old Nov 2, 2023 | 07:34 PM
Agree mph is down.
so I guess the what to spend money on question is a strong tune.
Old Nov 2, 2023 | 08:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Work on that 60 and what RPM are you shifting that combo at?
Old Nov 2, 2023 | 08:19 PM
Originally Posted by TrendSetter
Agree mph is down.
what kinda of mph at the track or even h.p on a dyno should I have so I know what to look for if the tuner can look at it soon. I thought a 1.8 was good but you guys are saying i should be in the 1.6 range?
Old Nov 2, 2023 | 08:25 PM
slothman's Avatar
50 to 75 wet shot. cheap solution and gets you better 1/4
Old Nov 2, 2023 | 08:30 PM
Magnet's Avatar
I’d say a goo dyno tune. Even 346 Ls1 with Bolton’s in similar weight car will trap 112. Your leaving power on the table.
Old Nov 2, 2023 | 08:39 PM
slothman's Avatar
wait a minute ....
you bought a boosted car ....and you don't know if it was dyno tuned or have any numbers ?
if that's the case, get that bitch on the dyno ASAP and stop going WOT. I mean really it shouldn't be driven.
it doesn't take much to blow the motor. just one lean run with too much timing will pop it FAST.
Old Nov 2, 2023 | 08:40 PM
RonSSNova's Avatar
100% agree. I built a very mild LS3 for my buddies full weight 70 Cutlass 442 clone.
It's an auto, but has run 11.60's @113. And I think his mph is a bit low. I'm sure it's every bit as heavy as your Chevelle.
I'd bet given what you said, it has no timing due to no intercooler. Or does it have one now?
I assume pump gas?
What EFI system?
Ron
Old Nov 2, 2023 | 09:31 PM
rpturbo's Avatar
Can I just start with, where are you located? If you're up in Colorado........
Old Nov 2, 2023 | 09:44 PM
During the dyno he only ran the motor up to around 3k and said its slipping and hot intake temps forced him to shut it down. Was told the tune he made should be fine for a basic setup like mine. I've changed the style of tensioner and installed an air to water intercooler since. Sounds like I need to get back on the dyno. Oh it's a holley terminator
Old Nov 3, 2023 | 12:58 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Just as an example of how much mph you are missing, years ago my barely under 4000lb m6 GTO with a stock cam and heads 5.7 would trap at least 125mph on 10psi with a rear mount turbo on a terrible 60ft. It trapped as high as 129mph on a hot lap. You are WAY down on power with a cammed 370 at 10psi.
Old Nov 3, 2023 | 05:38 AM
ddnspider's Avatar
your tuner never finished the job. It's probably pig rich with no timing and assuming he is competent the car will feel like an animal when tuner correctly compared to now.
Old Nov 3, 2023 | 06:10 AM
OK. I'll try to get back on the dyno and see what's going on. Thanks for the help guys! I'll post back results after
Old Nov 3, 2023 | 06:22 AM
Y2K_Frenzy's Avatar
What cylinder heads? Ported stock ‘71 SBC heads? How well do those flow? Are they better, worse, same, as stock 5.7 LS1 heads? Just curious mainly because everyone says he’s down on power.
