Proform brushless cooling fans?
I ordered a flexalite 236 which is a 16” non brushless fan, costs $120 and is rated at 2660cfm (vs 3400 for the preform brushless I have that I’m having problems with).
then there’s a flexalite 238 which is 16”, rated at 3000cfm and is about $190. It’s non brushless too. I’m trying the 2660cfm one first. It pulls less amps. The pro form is 20 something amps and my voltage at idle (with the 12” already running) is 13.2v, when the 16” come on, it drops to 12.7v. It does have soft start so I see it slowly drop until the fan levels off and then it ends up at 12.7v.
me having been into RC vehicles and into brushless technology, I can tell you with certainty that the main benefit is far more power output while using less amps and a motor that essentially never wears out, there’s no brushes to wear and the motor doesn’t get weaker over time like a brushed motor does.
and get this: the controller is like $43!
https://www.proformparts.com/product...fan-controller
edit: I see where it’s a manual controller. But the fans are pwm capable when using the third wire.
I also do find they get weaker as the heat weakens the magnets. Since these are fans I’d be worried about heat soak from the rad and engine.
I was reading about water pumps the other day and read where the consensus was flow cooler pumps were not good or reliable. I do feel like I need a little more water flow because if I raise the rpm at idle some, the temp will come down a couple to a few degrees. My theory is:
1) I have an underdrive pulley on the crank
2) my idle rpm isn’t much higher than stock because the cam I have isn’t big so it doesn’t need to idle higher
3) I have a bigger capacity aluminum radiator and maybe the original 2004 stock pump just doesn’t flow enough plus the two reasons above
idk why they aren’t. Mine is prob 7+ years old. It comes with a billet impeller that supposedly doubles flow at idle and low but doesn’t cavitate at higher rpm’s like stock. Mine has been problem free and the turbo 5.3 runs cooler than the 5.3 in the vette which has a large 2 core rad and brand new LS3 Camaro waterpump with aftermarket 160 Tstat. That engine at idle the temp increases to 198-199 at idle and as soon as it give it rpm the temps drop to high 180s. The 5.3 turbo with flowkooler pump idles the same temp and doesn’t increase while sitting still. That also has a big afco racing 31x19 two core rad and 160 Tstat. My experience has been the opposite. The racing world says push as much water as you can as fast as you can to lower the delta T in the system. A larger rad provides more fluid but more surface area and max out the airflow. It has worked for me!
5.3 turbo is 700-750 rpm idle
5.3 ls3 pump 600-650 rpm idle
underdrives do no good at all except maybe save the alternator if your spinning dumb high.
I don’t really WANT the underdrive but I have no choice because my drain line is in the front cover and the stock pulley would hit my drain line.
Being I'm turboed, i've been running into "overheating" problems down here in the south during the summer. I say "overheating" because it runs warmer than I like, I've seen 220ish.... not cool. No pun intended.
I Built an aluminum shroud to house the fans, but I wasnt sure what route I wanted to take. I know I want brushless fans but the only thing I saw that looked good was the Deltapag fans, but it would cost me a grand or more for two fans. I don't have that kind of extra cash for those so I was thinking about buying one flex a lite 238 (16" 3000cfm $169) and a deltapag 12" with controller (2100cfm $469 yikes). I accidently came across the Proform brushless fans, but they are too new to find any feedback or reviews on them. Just wondering if any of you guys have tried them yet, Or am I gonna be the guinea pig?
https://www.proformparts.com/brushless
Please note the DeltaPAG $469 price tag includes a digital temp/speed controller, dual 70amp panasonic waterproof relay/fuse module, sensor & 3ft waterproof wire harness and the fan & ECM. It's really an amazing deal considering what you're getting. Also, you only need one controller to operate multiple fans so the second fan would be $100 cheaper. Yeah, brushless fans and variable speed is like french fries and ketchup... there's no point of one without the other.
The fan leads look nice and thick which makes me happy having melted wires with the Derale fans lol.
