Help me figure out my boost issue
The car has hard mounted boost pipes and ever clamp/ coupler/ up pipe down pipe vac line ect is all in tact. Sprayed brake clean all around the intake no changes in idle. I’m lost
If the log shows map sensor ‘acting correctly’ in vacuum it’s probably not that. It’s going to be bad or it won’t.
I would go over all the piping between turbo and throttle body again. Boost leak test if you can.
what does the map sensor actually read? It sounds like you’re trying to tune by braille and you really need to embrace data logging in this day and age.
