Vacuum leak
Not sure I would be relying on the IAT sensor RIFE or not to pull timing to save my engine, kinda sounds like it was really spicy to begin with.
My cam is pretty choppy too, idles around 850-900 rpm with an AFR of .95-.96 and about 11-12 inches of vacuum.
Just install the sensor and then modify the IAT table with the values provided by RIFE.
Easy peasy.
Other setups I’ve found the crank keyway was retarded 8-9*. Which did no produce the glowing headers. But it produced low cranking compression and a huge drop in power. Once corrected I gained just under 12 mph at the same boost level.
Slide under the car and yard the pan off and see what you can see.
@Forcefed86 is there a way to tell if the reluctor wheel had moved without removing the pan?
Or if you have an aftermarket ECU you can look at the crank pulses in relation to the #1 cylinder and the cam sensor.
