C6 Z06 new PB
Street Car Takeover came to Firebird Raceway this past weekend and I finally had a chance to run the car in a local event with decent air and good track prep. The DA hovered anywhere from 1500' to 2500' so it's actually pretty good air for around here and track prep was on point. The car ran consistent all day and I slowly kept feeding more power in on the leave and it kept going faster and faster and reset my PB several times in the process. These 6870s are just about all tapped out so it looks like I'm going to be forced to upgrade here in the future to something a bit larger. Ran my buddy Frank in the finals in his C7 Z06 which is #2 right now on the C7 quick list, he is just .006 away from the #1 spot and could have had it but just ran out of time tweaking at the event. We decided to split the pot at the end and just throw the chutes at the 1/8th since the track was getting cold and starting to go away and we were slipping and sliding up top.
Here is just a quick video of some of the passes at the event...
Thanks! Yes it's a glide setup with a 9" rear, still all stock style IRS suspension.
Last time it made right around 1450 on a dynojet but boost wasn't totally cranked, but I'm sure it has to be somewhere around 1500-1550 maxed. It was super consistent all day and there are a few more things I'm going to tweak but I think it's got 7.4x in it with these turbos. So far this thing has been hooking at pretty much every track and event I've taken it to. Just registered again for TX2K so hope to make some glory passes there.
It's a single 450 and twin 525s but I'm upgrading here in a bit as I've had to start mixing down E85 to around E75 to keep pressure up. I have an ID brushless controller/pump sitting here that I've been meaning to put in but I just don't have the time to do it so it's on the shops schedule at this point. That should get me around 20% more volume at the same pressure, draw just over half the current, and be a nice PWM configuration vs the current pump setup.
Congrats! That's a great looking and running C6!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
