Terminator X Traction control - Boost or timing?
Obviously, this traction control isn't the best set up, but I'd like to play around with it before I spring for something more advanced. Any opinions would be welcome!
I think you play with your boost curve to keep it close to hooked then you can use timing to tweak as conditions change.. You still need a reasonable tune to match the conditions, traction control in my opinion just lets you put a bit more power in case it will take it in portions of the track
I have TBM brakes on front and cut an aluminum disc, installed with the rotor and put 16 bolts in it to read. Don't have any pics handy
As far the question in the OP, timing is going to be faster and more reliable. Tune the boost curve first and then use the traction control to keep it in check. Using traction control as a bandaid for a bad boost curve is where you are going to have problems hurting things. If you have the TermX Max, you could even add in some TB modulation with the timing to help.
I run that SIRCH converter on my TermX max, with the factory abs sensor. It "works" but i haven't gotten a clean enough signal to actually attempt to use it for traction control. I need to rewire it and see how it looks.
He also did a video on a engine where a customer of his was doing exactly what Nic D said don't do.
Relying completely on the traction control to get you down the track, it will destroy some ****.
- Most factory ABS sensors are designed to work in conjunction only with the ABS module itself, meaning the signals are not really adequate without being boosted and filtered which is all built into the ABS module.
- The Holley inputs don't really have good filtering nor does the software have the ability to adjust things like custom thresholds, hysteresis, and debounce.
You can try to use something like the VR to hall effect converter from SIRHC Labs to feed the Holley a better signal that it can deal with or you can try to boost the signal using an op amp circuit of some sorts. People still have mixed results with this and it isn't necessarily reliable so the alternative is to just run some good active sensors and add a reluctor to the hub. Even with something like a Motec or Haltech where you can setup custom tables for the input to help smooth the signal and ignore noise it can still be a pain in the *** to get a reliable signal input at lower speeds with VR sensors.
If its 1/2 racing on runways we run only wheel speed slip % traction control due to how slick they are.
