Magnuson 2650
Headers are very expensive for the gtos and really only 1 7/8 primaries are the only non custom upgrade available over my current 1 3/4 primary headers. Not sure how much that would net me. 3” catback is easy. Heads I was considering trikflow as cast through btr with powdered metal guides.
Good luck on your build.
https://ls1tech.com/forums/market/1981014
PC also allows you to retain the cathedral heads as putting adapters on heads to run the 2650 ***** out seems really counterproductive, put the correct head to match the blower port.
But yeah, it would suck to have to eat the cost of that intake with the swap.
…or I wait until the f1r-103 comes out and get that so I can add more CFM to the equation?
I'd just wait for the bigger blower, then look at heads/headers/exhaust as the bigger blower may get you where you want to go on its own.
As suggested, bumping up the headers and exhaust is something that can happen now and inevitably you are going to need to do so with the next powerplant. Your using street oriented exhaust setup on a race blower, use race oriented exhaust setup on a the race blower and see what it nets you in the interim.
If you're staying stock block, the ARP CA625 1/2" studs seem to be what a lot of guys go to with the LS9 gaskets when going all out.
ARP does a CA625 in the 7/16" stud too iirc.
