Turbo dilemma
All of you, thank you for your time and sharing your knowledge.
14.7:1 is good for idle and cruise (very light load). I I increase load, I add a little fuel.
having fueling at 14.7 at wot is asking to destroy an engine. That’s waaaay too lean. 14.7 is meant for light loads only, idle-cruise-light acceleration.
The reason you have your fuel afr where it is, is because 14.7 at WOT is a lean condition
I sent my Circle D back because I thought there was an issue, turns out the trans was cooked.
Circle D sent me a shipping label though for $50 which was great, they got it turned around quickly and have been great to deal with which is why I recommend them.
Technically I'm over the recommended power limit for this converter but it seems to be working pretty well still with slip in the 7-8% range up top iirc.
Be really curious to see what it does at 20-25lbs. with the meth running.
I tried contacting PTC several times but was never able to reach anyone unfortunately.
Comp Inducer: 80mm
Comp Exducer: 98mm
Turbine Inducer: 82mm
Turbine Exducer: 75mm
Housing A/R 1.01 or 1.15
My current turbo;
Comp Inducer: 80mm
Comp Exducer: 117mm
Turbine Inducer: 96mm
Turbine Exducer: 88mm
housing A/R 1.30
would i see much of a difference between a 1.15 housing and the current 1.30?
Comp Inducer: 80mm
Comp Exducer: 98mm
My current turbo;
Comp Inducer: 80mm
Comp Exducer: 117mm
housing A/R 1.30
