Turbo dilemma
I've heard from several people that the bigger VS turbos are based on old tech and don't perform nearly as well as other name brand offerings.
Pulsar is another brand that makes a great turbo for the money.
There's half a dozen used FIS Borg turbos in the classifieds right now, I'd buy one of those before I bought a new big turbo from VS but maybe that's just me.
You have plenty of cubes to spool that turbo, a different cam won't make that big of a difference in your application.
I'd redirect that money on a quality converter and then get the tune squared away.
Those two things will make a huge difference, I'm betting you won't need to change anything else.
I'd get on the phone with someone from Circle D, PTC or FTI and see what they recommend.
@5200 on 91 pump gas 576. 12psi
A high-quality converter that's a little looser down low would let the turbo get into its efficiency range faster and couple better up top too.
I'm very skeptical about any converter manufacturer who claims their one size fits all converter is good to 1,200whp.
When I was in talks with Circle D and Protorque, they both recommended mechanical diodes and other options for the 1,000+whp level that would negatively impact the street ability of the converter so when Yank just slaps 1,200whp on theirs, I'm very suspect.
My current Circle D converter is good to 800-900hp and is well suited for street use, to go higher in power I'd need some of the options mentioned above which also drastically increase the cost of the converter.
What I'll end up with is more slip up top probably in the 10% range but we'll see.
An 80/88 is still a good-sized turbo btw, for faster response you'd likely need something a bit smaller, but I'd do the converter first.
If 5,200 rpm is likely all the rpm you'll see then I'd definitely move to a smaller turbo, the big turbines really only shine in the higher rpm ranges.
Is it a T4 or T6 flange on the turbo?
i agree, seems like a lot goes in to building good converters, i also question alot of companies and there claim. However i feel Circle D has it figured out. Jusy my opinion.
i changed from the T6 housing to vband housing, Vsracing offers one. The T6 took up a good amount of real-estate to mount.
what's your thoughts on a 73mm with 1.01 a/r exhaust housing?
I'm begain to question the efficiency of this Vs turbo
To make power out at 6,800 rpm with 400 cubes will require a turbo with a big turbine which will not be as responsive down low.
For a turbo, I'd look at a smaller unit and bring that rpm limit down to 5,500 or 6,000 especially since it's a truck and not a car.
I'd want lots of low-end torque to get it moving and not so much top end, something with a 76mm compressor and a smaller 85mm turbine.
Still an 80mm compressor but has the smaller turbine.
VSRacing 80mm billet wheel turbo T4 - LS1TECH - Camaro and Firebird Forum Discussion
You won't get much more than 12 lbs. out of pump gas unless you plan on changing fuels or adding meth injection so you should pick the turbo that will be most efficient in that range.
Is the AFR in the 11’s at least now when you are in boost? If your tuner is stopping at 5200 with no explanation as to why... get a new tuner. That cam (with the correct springs) should pull well past that with your setup. Shouldn’t fall offline until 6700+ . If it is, something is wrong.
The converter is absolutely key and likely the most important part on a turbo setup. You should never be worried about power below 3500 as you should be flashing to 3500+ immediately when you stomp the gas. If not, you have the wrong converter. (wrong converter for your turbo anyway). If you want lockup, just ask for Circle D’s loosest non diode lockup converter. I’ve yet to see a circle D converter stall to the RPM they quoted it to. They have always been tighter than quoted.
last I spoke with them the “pro series” 258mm converter was available up toa 3700 rpm stall. (may be new options now) When purchased the “3700 RPM stall” only flashed to 3400 behind a moderate cam 6.0 w factory heads.
If he's making 12lbs. at 5,200, it should carry out to 6,700rpm without issue regardless of the map sensor.
Maybe the OP can post the tune file?
I wouldn't do anything until I addressed the converter if it was me and get a second opinion on the tune.
I think mine is the 258mm as well, stall has to be up there somewhere, I've run it up 4,000rpm on the TB, I think if you want more stall, it's the next size down diameter iirc.
It drives really nice, doesn't generate a lot of heat and seems to lock up quite well on the street.
As I said, the fact Yank says theirs is good to 1,200whp and is so cheap is a red flag to me when Circle D, ATI and ProTorque have come back with something totally different and way more expensive at that power level.
what determines the a/r size for the exhaust housing, or what are things to consider?
If you want to shift at 6,800 rpm, I wouldn't do a Precision 7675, you've already got the room for a large frame turbo so stick with it.
If the tuner says the 2 bar sensor is the problem and you intend making more boost anyway, upgrade to the 3 bar, put it on E85 and see what it does.
Don't throw anymore parts at it like a cam or turbo until you get it running right or you may just end up flushing money down the drain.
Post the tune here if you can, lots of guys here who can tell you if it's where it needs to be.
If the tune is soft on timing down low, that'll affect turbo spool, lots of little tricks experienced tuners can employ that your guy may not be aware of.
I’m confused by what cam you are actually running? At one point above you said you had a SS2, now you are talking about switching to a SS2? I was thinking you had the Tick Performance SNS LS2 stage 2 231/235 in your signature. Which is a better cam than the SS2 for a 400" motor.
The sloppy is a 228° / 230° on a 112. That will behave similarly with less power all round with less peak rpm. Silly to change between the two.
You have a relatively large motor. You don’t want to go from your current S480 87mm turbine wheel to 75mm turbine wheel. It will choke at moderate power/RPM on such a big motor. Walk away from whomever is putting these suggestions in your head.
Don’t replace BS parts just to replace them. Replace the converter. That’s the issue with your current combo.
Nothing is wrong with the cam or the turbo. If you read about the SNS LS2 stage 2 231/235 cam (we assume is in your car now) it states 3600rpm stall recommended. And 6600 rpm peak. You can generally squeak out an additional 500-1000 rpm with a turbo combo from the rated rpm. You can’t run a factory converter with that cam and expect it to perform well.
I agree, and felt the same way about only making power to 5200, regardless of the MAP. and i though the 2bar table should've covered at least to 15psi.
The reason I would like to swap cam, is to gain better torque lower in the rpm, out of boost. It is an idea i had.
Overall Something is definitely not right with the truck/tune whichever it is.
I will post the tune later tonight. A problem with the truck came about, not that the tune caused it, i would like to get opinions on the tune first.
The SS2 cam is a bit smaller and may peter off earlier than I thought on a 400” motor. Esp if you have decent heads on it. You can look at all the Holdner 6.0 tests and see it routinely pulls to 6600 or so on an NA 6.0. I’d go bigger for your motor, but I don’t think thats the 5200rpm issue. No matter what I’d change the converter first. Its a night/day diff.
I'm not set on having to have the power up to 6800, not if that means sacrificing low-mid power. i feel a larger cam would result in this, I agree about the 5200 issue not being related to the cam selection, something else isn't jiving.
Wait and see what it does, that may be the only change needed parts wise.
Currently I run an S484 with the 96mm turbine and 1.36AR on a little 5.7 and it'll start building boost around 3,600rpm which is where the converter is working so imagine what yours will do now.
