Wastegate Springs
Old Jan 25, 2026 | 03:18 PM
91 Z28's Avatar
Default Wastegate Springs
Hey guys quick question so I got a new 50mm Turbosmart gen 5 gate it says the 14 psi spring is installed but turns out the 7 and 5 psi springs are in there for 12 psi. Would it be better to run a slightly less spring and use more controller than a heavier spring with less controller?? Everything is controlled by the Dominator ecu and target boost is 25 psi for now. Turbo is a TNT 88/96 T6 with the gate inline before the flange. I'm also not running Co2 or on board air it's just plumbed from the compressor into the bottom port and into the mac valves. Thanks guys.
Old Jan 25, 2026 | 04:40 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How are you going to make 25 psi without C02?
I'm running 2 46mm WGs, single midframe 85, and am running 3 lb springs. But when I next have the engine out I'd probably switch to 6-8 lb springs though I don't need to.
Old Jan 25, 2026 | 04:46 PM
91 Z28's Avatar
I can make 25 psi no problem. The current gate has a 14 psi spring and I'm using a dome pressure sensor in the top of the gate. Pic is the dome pressure curve. Haven't seen any oscillation on the logs using this curve and I'm using a 10.5/35/0 PID settings. I also have a back pressure sensor on the turbine housing but need to get a canister for the sensor as the readings seem crazy. Also using a GM 4 bar map sensor 25203477 which reads up to 44 psi
Old Jan 25, 2026 | 04:56 PM
LS1Tech Co-Founder
Nice, I had my combo make 18 psi in 1.2 seconds, 8 on the leave, but I have to use C02. Without a wg reference it would make about 14 psi at 7100 in 1st gear.
Sorry if I'm taking your thread on a tangent.
Old Jan 25, 2026 | 04:59 PM
91 Z28's Avatar
No worries. I've never actually given this any kind of thought so I'm curious to know what everyone's thoughts are on this. I've been considering getting a Motion Raceworks CO2 setup since I've got no back seats I'd just mount the bottle beside the fire extinguisher
Old Jan 26, 2026 | 11:24 AM
Black_Sunshine_99's Avatar
Depends on how much BP you're seeing in the hotside.
I tried 3-4lb. springs in my last car which was a single 44mm on an LS1 with a 7875 and the BP would push the gate open prematurely. I stepped up to a 6-7 lb. spring and got my control back.
I run 6-7 lb. springs now and made almost 16 lbs. using reference pressure and then 22 using compressed air.
For a streetcar I'd do compressed air before I did CO2.
Old Jan 26, 2026 | 12:37 PM
91 Z28's Avatar
What's the "go to" air compressor for boost control??
Old Jan 26, 2026 | 01:23 PM
LS1Tech Co-Founder
Viair is popular.
If I ever find my box of wg springs I'd swap out the 3-4 lbs springs I have in the WGs and go to 6-8 lb springs.
Old Jan 26, 2026 | 01:45 PM
91 Z28's Avatar
I'll give a look into those compressors
Old Jan 26, 2026 | 05:07 PM
This is the one I use, works great. Fills the tank in about 1-2 minutes and is pretty quiet. If you can make sure your system is leak free it'll hold pressure much longer. It never really bothers me, so I haven't put any effort into finding all the little leaks.
Amazon.com: VIAIR (10000) Ultra Light Air System : Automotive Amazon.com: VIAIR (10000) Ultra Light Air System : Automotive
Old Jan 26, 2026 | 07:15 PM
91 Z28's Avatar
That actually looks like a really nice system at that price too! I never really looked into air compressors. My reason to lean towards going with CO2 is that I can get bottles filled for free. But now it's kinda got me thinking about air
Old Jan 27, 2026 | 09:06 AM
If you can get the bottles filled for free, then that's definitely a plus.
My whole thing is if you forget to turn it off and it leaks out, then the next time you go to drive you're out whatever the CO2 powers.
Plus, with CA you can air down your tires at the track and fill them back up.
Old Jan 28, 2026 | 09:05 PM
jayyyw's Avatar
It ultimately depends on how much resolution you want/need out of your setup. Are you traction limited as it is now? If so, you don't want to put more wastegate spring in because that will make it worse. If not, and you can get away with more boost before traction becomes an issue, then you can add in some wastegate spring.
I like to keep just enough spring in the gate to where you can have fun on the street without getting dangerous, on the wastegate setting. Then use the ECU to add boost from there. Having a rotary switch definitely helps in that regard because you can change your boost on the fly (as long as it's configured).
I also run the Viair system. Its pretty convenient and you don't ever have to worry about running out. And then, like mentioned above, you can plumb in an air hose to top off your tires if needed. Some people will use it to blow out their rear mounted radiator setups because they can accumulate debris. I run AN lines on mine and don't have any leaks.
