Dynoed the T76.
Old Aug 5, 2004 | 06:00 PM
MYTURBOT/A's Avatar
Default Dynoed the T76.
Finally got the car dynoed with the 76.
This is @ 12psi on the same tune the 60-1 was running, except I adjusted the fuel to get the A/F close, Which actually turned out very close.
Maxed out the maf at about 5000rpm so that's why it gets leaner up top. I'm gonna adjust the tune a bit throw a LS6 intake on along with a walbro fuel pump. Then i'll bump the boost to 15psi and see what she lays down.
Not bad though I gain 110rwhp and about 70rwtq just from the turbo swap.
Old Aug 5, 2004 | 06:05 PM
MYTURBOT/A's Avatar
I'm hoping after the LS6 and a cam swap I'll put down 650-675rwhp @ 15psi. Do you guys think this is possible?
Also I'm gonna replace my stock intank pump this weekend. Can I leave my stock pump in there and run it like a twin setup with the walbro? I want to be safe but i think twin walbros would be overkill.
Thanks
Old Aug 5, 2004 | 06:35 PM
MIGHTYMOUSE's Avatar
wow man thats great, what a turn around.. be sure to let george know the good news! i can only assume you are really happy with that!
Old Aug 5, 2004 | 06:58 PM
Earl H's Avatar
There is no reason why you shouldn't be able to get to 650rwhp. I am running a similar setup only on a Z06 (single turbo T76 GTS). At 14psi, I am at 650rwhp on pump gas and pretty conservative timing.
Old Aug 5, 2004 | 07:51 PM
MYTURBOT/A's Avatar
Thanks,
Yes I'm very happy with the results. It didn't look like i was ever gonna see the light at the end of the tunnel. Now it's all coming together. Hopfully George will see this post if not i'll give him a call to let him know.
Old Aug 5, 2004 | 07:56 PM
SSnakekiller's Avatar
Nice! Any idea what your spark advance is and your intake air temps????
Old Aug 5, 2004 | 08:08 PM
MYTURBOT/A's Avatar
Spark advance is 16* @ TQ peak ramping up to 20*@ HP peak. IAT averaged 100*F base 139*F at the end of a pull. Kinda high but it works for now.
Old Aug 6, 2004 | 12:33 AM
69firebird's Avatar
congrats to you, i know this has been a long time comming for you, glad it is all comming together
ed
Old Aug 6, 2004 | 12:41 AM
KHShapiro's Avatar
very nice
Old Aug 6, 2004 | 05:59 AM
smokinHawk's Avatar
Thanks
congrats on the numbers those are great!
how many psi were you runing with the T60?
i tried fitting a walbro and the stock pump in the pump housing but couldnt get them to fit. so i got another walbro.
Old Aug 6, 2004 | 09:52 AM
andy98Z's Avatar
Nice power numbers. 110rwhp was well worth the swap.
Old Aug 6, 2004 | 10:25 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
TT street kit or race kit? Or however they differentiate.
Old Aug 6, 2004 | 10:45 AM
smokinHawk's Avatar
street i believe
Old Aug 6, 2004 | 12:29 PM
MYTURBOT/A's Avatar
Thanks.
Yea, It's the street kit.
I was running 12psi on the 60-1 when I made the 425rwhp 500rwtq.
Here's the 12psi 60-1 graph.
https://ls1tech.com/forums/attachmen...achmentid=7742
