Turbo is on...
Old Aug 16, 2004 | 12:11 PM
CHRISPY's Avatar
Wow that isnt bad!!! How well is your oil return working?
Chris
Old Aug 16, 2004 | 12:13 PM
slyws6's Avatar
Well I'm kind of being risky, I have an oil pressure gauge in the car but still need to route the wire. I know it's getting pressure because I pulled one of the lines and there was plenty of oil in it. Also you can hear the pump really loud when you turn the key on but when you start the car it gets quite (meaning it's pumping oil). I plan to run the wire tonight to see what kind of pressure I'm getting back to the pan.
-Sly
Old Aug 16, 2004 | 12:14 PM
slyws6's Avatar
I also need to put a check valve in the pressure side so the oil doesn't drain back down the hose part way after turning it off.
Sly
Old Aug 16, 2004 | 12:16 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Remember a turbo needs about 2 gallons per min at 30-35psi.
Jose
Old Aug 16, 2004 | 12:18 PM
slyws6's Avatar
It's getting pressurized by my oil pump running, my oil pressure runs around 60psi at idle and low rpm's. The return pump...well I'm not sure until I get the gauge hooked up tonight.
-Sly
Old Aug 16, 2004 | 12:27 PM
frcefed98's Avatar
Sounds awesome, can't wait to see the pics. Gotta love the innovators out there. You get a big from me for doing something like this. I hope you see the numbers you are looking for, do you know where to get it tuned? Any good tuners in your area?
Keep the info coming
Old Aug 16, 2004 | 12:32 PM
slyws6's Avatar
Well I have HP Tuners so I will be attempting the tune myself. I'm sure there will be lots of time involoved.
-Sly
Oh ya, thanks for the kind words.
Old Aug 16, 2004 | 03:09 PM
Machine's Avatar
That car's gonna be sick fast!
Old Aug 16, 2004 | 03:18 PM
JRL96TA's Avatar
You can get that oil pump here. http://www.racerpartswholesale.com/mocal1.htm
Old Aug 16, 2004 | 04:51 PM
NOSjohn's Avatar
Restricted User
Doesn't STS use a boost reference switch to increase/decrease voltage to the pump to
raise/lower pump volume while under boost?
Old Aug 16, 2004 | 05:55 PM
01 SS Jay's Avatar
Is it a good idea to power the oil pump from the fuel pump wire? Wouldnt it would be drawing power at a time when you need it most - wot? Might be a good idea to run a dedicated hot wire back there.
Old Aug 16, 2004 | 07:45 PM
  #32
slyws6's Avatar
This is true however I am buying a fuel system this week that has a hotwire that goes to the pumps so this should be fine. Until then I will not go WOT.
-Sly
Old Aug 16, 2004 | 08:16 PM
  #33
slyws6's Avatar
Here's the pics, keep in mind the hose clamps will be replaced with band clamps (when the right size gets here) and the duct from the pipe to the MAF will need to be replaced with one that fits better. Also a new airfilter and cover are in the mail, the that's on there is temporary.
-Sly
Old Aug 16, 2004 | 09:08 PM
  #34
dynedta's Avatar
chronic masturbator
wow other than it looks alil too low i think it looks great do you want to produse me a kit?
later
Gary
Old Aug 16, 2004 | 09:27 PM
  #35
O2bqwik's Avatar
i am very interested in how much power this setup puts down. good luck to ya
Old Aug 16, 2004 | 09:31 PM
  #36
O2bqwik's Avatar
lol what happens when that 10 bolt blows? looks hard to pull the rear end
Old Aug 16, 2004 | 10:09 PM
  #37
slyws6's Avatar
It can be raised up another 1 to 1 1/2 inches in which I need to do, just minor adjustments here and there. As far as producing the kit I thought about it, however I cut a couple of pieces to get mine to come through this location. I plan to put a modified lid over it to hide everything (notice how low the BOV sits etc. You can bring it up in front of the radiator on the drivers side as well.
-Sly
Old Aug 16, 2004 | 10:49 PM
  #38
F8L Z71's Avatar
12 Second Truck Club
Very cool!
I'm interested to see how it works out. I'm now using a GT67 with a .96 exhaust housing and so far I'm told it spools really nice. Better than the GT67 and T70 setup on the other 2 cars they are working on.
Keep us updated
Old Aug 16, 2004 | 11:58 PM
  #39
solobaric's Avatar
Very nice job man.
Old Aug 17, 2004 | 01:01 AM
  #40
distortion_69's Avatar
Bring it to Steele today
Peace,
Josh
