One way check valve? Where?
Old Aug 19, 2004 | 12:01 PM
Unusual T/A's Avatar
Default One way check valve? Where?
Where can I get one? I don't know the first place to start looking.
Thanks
Old Aug 19, 2004 | 12:11 PM
slyws6's Avatar
Ummm autostore PCV valve.... not sure what you need it for but I used one to keep my oil feed from draining when the car is off.
-Sly
Old Aug 19, 2004 | 12:25 PM
-Sly
I was told I needed a one way, it had to do with crankcase pressure and oil or something.
Old Aug 19, 2004 | 12:29 PM
slyws6's Avatar
Yes a standard PCV valve will only allow things to blow one way. If you go to the auto store, open a package with a pcv valve in it, then try to blow through each end of it, only one end will let you, thus it's one way only. Oh and PCV valves are for crankcase pressure and oil as your talking about
-Sly
Old Aug 19, 2004 | 05:43 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah they do work for mild presure Unusual T/A but if you are running boost of any kind check out www.Mcmaster.com they have some brass check valves that can be placed in the pvc system to keep from blowing boost into the crank case etc...
Old Aug 19, 2004 | 06:41 PM
There are like 7 different brass valves there. You're gonna have to narrow it down for a brotha.
Old Aug 19, 2004 | 07:57 PM
2001WS6Vert's Avatar
The popular one is the 1/4" 7775k52. I thought it looked a little small so I changed to the 3/8" 7775k53 which is a lot bigger (better flow). You'll have to get a couple brass fittings that will have outlets for 3/8" hose.
Old Aug 19, 2004 | 10:38 PM
TT-TECH Veteran
Yeah I ordered both the 1/4 and the 3/8 and I used the 3/8 valve worked very good.
Old Aug 20, 2004 | 11:39 AM
libertine1015's Avatar
Cap off your Intake and use vaccum from your air inlet before the Turbo or S/C then you dont have to worry at all about reverse pressure. Works great with the LS6 Valley cover. I just switched over to this using two Metco breathers, one in each Valve cover. Got the mod from Mighty Mouse. I tried going the checkvalve way but with my relocated Alt I didnt have much room and I always worried about the valve getting stuck open by crud and leaking boost into the motor.
Old Aug 21, 2004 | 09:44 AM
red ws6 99's Avatar
Only problem with hooking up to air inlet is you are going to suck a lot of oil into the line from the valve cover. Which is going to get into the turbo, intercooler, maf (real bad), etc. Breathers work really well and no oil into intake track.
Gary
Old Aug 21, 2004 | 02:31 PM
KAOS's Avatar
how are you guys tying these into your current pcv systems, what kind of connections are you using to get them to work with the current setup
Old Aug 21, 2004 | 02:54 PM
It would be good if someone could draw us a diagram.
Old Aug 21, 2004 | 11:38 PM
KAOS's Avatar
i just want to know how you are connecting the hoses. there is one with 2 male ends would it would be any different
Old Aug 21, 2004 | 11:41 PM
KAOS's Avatar
and doesnt the pcv system work the same way? where does the pressure go? and would just be venting the sysetm to atmosphere work better
Old Aug 22, 2004 | 05:03 PM
To the top for us both.
Old Aug 22, 2004 | 07:45 PM
red ws6 99's Avatar
If you want to run a pcv system here is how the Incon setup is stock, it works great no crankcase pressure.
Ok
1. Tie the driver side valve cover into the passenger side valve cover. Should be like this from the factory.
2. Remove vacuum line from top of throttle body and cap.
3. Place one way check valve infront of the pcv valve. This will prevent boost from entering through the pcv valve.
4. Run a hose from the driver side valve cover to the just behind the air filter but before the turbo inlet or supercharger inlet. This will have a vacuum on it under boost but otherwise won't do much.
Gary
Old Aug 30, 2004 | 12:39 PM
KAOS's Avatar
gary cant your way suck oil into the intake track of the turbo? i have the qmp kit and it will pull vac on that line to the valve cover if i hook it to the filter or along that path, correct? is there a way to eliminate the pcv all together
Old Aug 30, 2004 | 04:42 PM
Scalpel's Avatar
Don't eliminate your PCV, Daniel.
Old Aug 30, 2004 | 05:28 PM
why not doood?
