what a/f do you get max power?
Old Aug 25, 2004 | 06:32 PM
cablebandit's Avatar
Default what a/f do you get max power?
I played a little today with my setup from mid 11s to 12s a/f but it lost power coming from 10.9-11.0 ish. where have you found your setups to make the most power?
Old Aug 25, 2004 | 07:09 PM
MECHAM's Avatar
the leaner you go the more power you will make. (not too lean tho)
for a FI car...i would guess 11.5 would be a good safe tune.
its not worth a couple of more ponies for 12-12.5 if things go wrong and BOOM
Old Aug 26, 2004 | 05:00 AM
smokinHawk's Avatar
i think most of us FI guys tune to 11.5
Old Aug 26, 2004 | 05:54 AM
Slowhawk's Avatar
LS1Tech Sponsor
11.5-1 on the street and 11-1 A/F on the dyno.Most power could be made at 12.5-1 on the dyno,but it won't last too long.
Old Aug 26, 2004 | 10:09 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Typically 11.0-11.5 is your best bet for HP and safety margin.
Jose
Old Aug 26, 2004 | 10:22 AM
Ed Blown Vert's Avatar
Hmm, maybe I should change mine. I run 12.0
Old Aug 26, 2004 | 10:26 AM
PurEvl's Avatar
graph in sig
Old Aug 26, 2004 | 11:01 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
12:1 on a Dynojet would be overly lean on the street IMO.
We've been racing my car at 11:1 to keep it safe.
Old Aug 26, 2004 | 11:04 AM
MECHAM's Avatar
Originally Posted by 5-liter-eater
graph in sig
thats a nice tune
Old Aug 26, 2004 | 11:28 AM
Black LS1 T/A's Avatar
Moderator
graph in sig
My A/F looks simliar. It's About 11.2 ~ 11.4:1 thru peak torque and leaning to peak power (power drops at about 6400... this was at about 8 or 9 PSI in 3rd gear). I've got more fuel now, so I may be able to give it more fuel (and more boost) over 6000 RPMs.
Old Aug 26, 2004 | 11:34 AM
LS1TECH Sponsor
John hit the nail on the head. A dynojet in our experience is about half a point out (richer) then what the car will run once it sees a real load on the street. A Mustang dyno is the only way to get the accurate reading as well as getting dyno results.
Jose
JERRY2500's Avatar
14 Second Truck Club
11.5~12
Old Aug 26, 2004 | 12:01 PM
PurEvl's Avatar
Originally Posted by SC-MECHAM-WS6
thats a nice tune
thanks, only problem is the belt slip I had, would have been 650+ if it didnt fall at 6500-6800
