F.I guys with wideband
Don't forget to calibrate your wideband often. It says to do so in the instructions of my LM-1...especially if running a rich turbo setup. I hadn't recalibrated mine since it's initial install and it was off which explains some tuning confusion I had.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Must be specific to the newer widebands using the bosch sensor. The old ntk sensors don't vary much at all. But calibrating any controller or sensor would not be a bad idea.
Gary
Gary
Tech Addict
Originally Posted by 2MuchRiceMakesMeSick
How do you calibrate one, is it a pain? I will be buying a wideband soon.
unit's that use the built in trim resistor in the sensor connector don't require recalibration. I beleive the LM-1 does some heater calibrations and nerst cell testing to get a better temperature comp for the sensor output.
my AEM units don't, my Techedge (NTK) require a manual tweak when you swap sensors only, my LM-1 has the cal button
Yes, I've got 4 WB's( one is dual channel)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
The newest tech edge (LSU) has a calibration you run from a PC, it does change quite a bit after a while. I recalibrated mine when I sold the car and it was pretty far off as far as the numbers in the calibration utility went - dont know how much off it was as far as a/f though.
The older tech edge I had (L1H1) never changed after months of use, it just had a trim pot to calibrate it.
Tech Addict
Originally Posted by NA$TY-TA
Were do you guys mount the display those who ahve the LM-1???? Im looking at getting one here soon.....
Thanks Kyle
Thanks Kyle
Also my readings were in third at wot so I could basiclly hold it and watch it also when she was not there.
Originally Posted by Todd2001SS
I usually have my wife will watch it for me during live runs, but for the most part my A/F tuning started rich then was gradually brought up leaner so I could just record each run without danger.
Thanks
Kyle
Tech Addict
Is the bung that comes with this kit (LM-1) the same size as say the O2 sensor most places use to wideband our cars on the dyno?? Why im asking is because i have another bung already weled into place that Jayson at MTI uses when my cars on the dyno there for tuning..
Thanks
Kyle
Thanks
Kyle
