New kit pretty much done.
I'm using slip fittings on the WG instead of bolting it solid between the DP and inlet. You think if i used one of those stainless flex couplers on the DP, that would work to give the exhaust some movement?
I finally got a chance to go out and do some tuning @ 10psi last night but i'm running into a slight problem now I can't seem to get the tires to stay planted in any gear below 4th
This thing is gonna be impossible to street tune on 14psi.
ya a flex section or just some slip fit and clamps would allow enough movement so your stuff wount crack later.
I should be getting it on the dyno here soon. I finally broke down and bought a wide band and alky injection kit. Got the W/B installed, and once i get the alky installed and dialed in i'll pull it on the rollers and see what i can break.
what size primaries did you use? did you use the 2001+ headers as well (remind my memory)
how much power is that Gt45 good for?
good luck with the dyno we are all eager of your results, any trips to the track planned?
Jose
I'm using a set of 2000 manifolds dumping into 2.5in piping off the manifolds then Y'ing into 3in piping that goes all the way into the turbo.
I just drove the car from orlando FL. all the way to southern MN. to see family. Didn't use a drop of oil and got 27mpg. I was pretty impressed. But when i got back in town the next day I took it out and got on it real hard and broke the TQ arm mount. It sheered the bolts off the tail of the tranny.
Kinda funny considering after the first time i broke a tranny mount and about craped my pants. I ran a cable over top of the tranny and bolted each end to the crossmember to hold the tranny down incase i ever broke another mount.
So instead it just breaks somthing else. But anyway I just drilled out the bracket and put some new bolts in.
You turbo guys have all the fun!!
Im anxious to hear what that thing puts down once it is dialed in. Are you using alky instead of an intercooler currently??? Do you have plans for an intercooler later on?? So far i'm very happy with the turbo for the price it can't be beat IMO. There are some pics in one of my threads of all the piping and everything installed on the car i'll see if i can dig them up.
nate
nate
Thanks Carter, my Thanksgiving was good, hope yours was also.
