ATI procharger, help
I want to go with the P-1SC kit at 5 or 7psi and i have seen price ranges from 3500-4700 bucks for em'.
I want the full kit at 5 or 7psi (its adjustable right? according to the wastegate set up ?) and I have seen that you are given a programmer with one of these set ups and that is the one that costs 4700. IS the programmer ATI's programmer for the 7psi or is it a tuneable program you can use to tune your car for the 7psi??
I also know that the 3500 set up is the full kit w/o the programmer, I'm going to get my car tuned with LS1 edit at a tuning shop in durham so i don't think that i will need the progammer from ATI.
I'm going to call ATI and talk to them, I just wanted to know if anyone up here already has a set up like this and basic information about it.
we will also have a moser 12 bolt to have some fun with
Mark
My question is where are you finding the kits for $3500. If not a sponsor pm me
New D1SCs can be had for low 4Ks from our sponsors, they just can't advertise the price because ATI won't let then. You have to call them.
Mark
As for the D1/P1 debate. From what I've read and seen, the general consensus is if you are absolutely 100% positively sure you won't want to upgrade later the P1s are supposed to be more efficient at low boost levels. The D1 will move more air, give you more peak power, and give you more ability to grow. But the P1 is slightly cheaper and can give you more area under the curve at low boost. In general it's wise to pay the extra $130 to get the D1 from the get go. Upgrading later can be very costly.
Mike
Base D1-SC kit.. Say $4300
Racetronixs intank fuel pump $260
42# Injectors $350
Mechanical Boost gauge $50
Electrical Fuel Pressure gauge $200 has to be Electrical or is not NHRA legal(canot run fuel into cab)
A-pillar gauge pod $45
Wideband tuning on the dyno $500-$675
Total $5880
and then...... if your on a stock 10 bolt and you do get traction.... say bye bye rearend ($2500) and beefing up the tranny to take the extra power also..... Then if you have mods already and they send you a 4" blower pulley like they di dme back when i had a 6 rib setup and you make 4psi w/ a baby cam and LT's when they said you would make 8psi.... so $92 later after another pulley change you finally see the boost you want tna dthen you run into the dreaded belt slip issue......(wich we have solved now with the SDCE 8 Rib setup $700)... then there alway the possibility that a piston gives up........... just be ready is alll i have to say.... on most things ive been there done that with these ATI kits...... I finally have it doing what i want over a year later.......
Kyle
D1SC Kit from Speed Inc.
Inline fuel pump
42lbs injectors
Twin Innercoolers
Polish Plenum.
Only had it on for about 8k miles. Oil changed everytime.
Made 510rwhp on 6lbs pulley (only saw 4lbs of boost on gauge due to LPE heads)
That dyno was on a safe tune with my LPE Topend kit.
Call Speed Inc. they will tell ya how well I took care the kit and car.
I would have Speed Inc. install it to. They did one hell of a job.
$4000 for everything. Pics of the Procharger system are in my sign.
Email me if intrested. We can work out something. Been holding on to it for a friend who came on some hard times recently. So its forsale again.
but it is not cheap to upgrade.
Personally, if i was going to do a ATI blower, here is what i would do.
used D1sc, $1500-2K
SDCE spring loaded tensioner. $800
OBX front mount, with piping $600
ATI superdampener $500-600
then of course the other supporting mods. fuel system, clutch, ect.
Ryan
Like I said before, used kits go for 3K if you want to go that route
I said a D1SC kit, now do yourself a favor and use the "Search" key and you'll see what I am talking....not to mention its been said many many times, and i've only been in the FI section for a few months.
A little advice for you, if you plan on selling your kit, I would drop the price down to somewhere around 3500, that is a little more realistic.
