Which turbo for truck and why?
Here is the post with my little plan. Let me know where I am going wrong on it.
https://ls1tech.com/forums/showthread.php?t=230441
or... if you don't want to read it, just tell me which turbo (just the turbo itself) I should look @ getting.
My mods are below. They will not change before the turbo setup (if and when it happens) except for the addition of an eaton posi and some DRs....
Basically, I want (I think) a turbo that isn't some mini unit ripped off a volvo, but nothing for a huge deisel. I really would like a medium turbo to add about 50RWHP @ peak (6K rpm), add maybe 50-60 ftlbs from 2500-4500rpm, and not something so small that it will choke my low end (can a turbo really do that... choke your low end?)
Where do I go? Obviously I don't want to spend beau-coodles of money (after all, that is the idea of this "custom" thing) but I want something reliable.
Also, I have an 01 LS6 cam on a 116 LSA (I think). This should be turbo compatible right?
FMU and Walbro pump = $390 (cranking about 450, would this even be needed?)
Bigger Injectors = $175? (Again, same ammount of power, would this needed?)
Retune = $50
Intercooler = ? Do I even need it if I'm just looking for 60-75 to the wheels?
Turbo itself w/ wastegate= ~$450
Rigging up the oiling system (help with this plz!) = I figure no more than $200
Running the pipe = $300 tops
Manual boost controler = $50
Boost gauge = $75
Fuel pressure safety switch = $75
That puts it @ 1765 if I don't have an intercooler, which I am not sure I want b/c I don't want to make too much power. (Read: DRIVETRAIN)
That means for roughly 1850 given little extra expenses I could have:
turbo with wastegate
oiling system
fuel system
tuning
boost controller
piping
fuel pressure safety switch
boost gauge
hosing, etc
What could say a Garrett T04B V-trim do for the truck with mods below? What kinda boost would it run? What kidna power? Am I even looking @ the right turbo?
Thanks a lot!
-Derek
I put my engine with specs as close I could get them and it claims it makes 386/352 brake HP. TQ seems right, but the HP seems up by about 15 or so.
Anyway, with a Garret T04B V-series turbo air/air intercooled on 8 psi the computer says it will make:
452HP/442TQ on top of my current setup with it making over 400 ft/lbs from 2K-5700rpm) and peaking @ 6K still.
And then if I ever got crazy 12 psi would put me at 500hp-tq.
So, is this particular turbo something that deserves my attention?
As far as the injectors... WOW! I didn't know they were that much. I have seen howerver that some1 got like 36lb injectors out of a cobra relatively cheap and they worked with a little modification. (but don't hold me to that) One of those things I think I thought I saw.
The turbo with wastegate I have seen for 450. Summit sales a "turnscrew" boost controller cheap... boost gauge... I'm assuming there based on prices of other gauges.
The fuel pressure safety switch I think I saw for 75 when I was looking up nitrous stuff.
