STS Kit Problem - Need Help ASAP
Old Oct 23, 2004 | 10:47 PM
z383stroker's Avatar
Default STS Kit Problem - Need Help ASAP
I was driving my 2000 TA today with the STS kit and oil starting pouring out of the exhaust side. Not sure quite what happened. If anyone knows what possibly happened, please help. Need help ASAP.
Old Oct 23, 2004 | 10:51 PM
jcfreak's Avatar
Make sure all the bolts are tight on the turbo housing and make sure your vaccum pressure switch is working.
Kevin Lucas
Old Oct 23, 2004 | 10:53 PM
Slowhawk's Avatar
LS1Tech Sponsor
Oil return pump problem.Did you put in the pressure switch under the hood that controls the pump speed? Happened to me and alot of oil came out the exhaust and into the intake track.Replaced that switch and it has been fine for over 1000miles.
Old Oct 23, 2004 | 11:43 PM
trtturbo's Avatar
Pull the one way pressure valve off and see if it drips when connected to the steel braded line.
If it does, that valve is bad. Also, you may check the harness and make sure it is not melted and grounding out.
Old Oct 23, 2004 | 11:49 PM
Which one is the one way pressure valve? I'm not real famillar with the tubo yet so help me out with specific and what connects to what.Also what harness are you talking about?
Old Oct 24, 2004 | 12:09 AM
trtturbo's Avatar
The steel braded line goes into a valve on top of the turbo that will keep oil from dripping in without pressure behind it. It is about 2 inches long and round.
The harness that gives power to the pump; runs from the front pass side. Make sure it has not gotten against your exhaust. It will melt and could ground out.
Old Oct 24, 2004 | 12:11 AM
Talking
I will check it and get back to you on it. Thanks man for the advice.
Old Oct 24, 2004 | 02:43 AM
The vlave on top drips oil out when you turn the oil pump on. Do you mean that it should not open at all until there is pressure on the turbo. The wires seem fine no melting spots. Let me know. Thanks for all your help so far
Old Oct 24, 2004 | 08:44 AM
trtturbo's Avatar
Not when you turn the pump on. I'm talking about the steel braded line that goes into the cylindrical pressure valve that goes to the oil feed hole on top of the turbo. If you take the steel braded line off, oil will start to drip out of the feed line. Take the pressure valve off and put it on the steel braded line. It should stop dripping after a few more drips. If it continues to drip, them the valve needs to be replaced.
If you would like to, click on the link and call me. I will see if I can help you over the phone.
Old Oct 24, 2004 | 09:02 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
The other thing to consider is if you were parked one a steep grade. Turbos are sealed with something akin to a piston ring and if your vehicle gets to an extreme angle, oil will flow over that ring and into the turbine.
Old Oct 24, 2004 | 01:42 PM
Hey man I tried calling you and there was no answer I'm going to PM you my phone number so give me a call when you get it. Thanks Matt
Old Oct 25, 2004 | 11:48 PM
Well I do appreciate all the help guys. I talked to Rick the designer on the turbo and he said that it was the oil pump but the pump is fine so he suggested taking it to one of there dealers her in atlanta si I will see what happens with it
Old Oct 26, 2004 | 05:32 AM
quicksilverado's Avatar
Who is the Atlanta dealer? I did'nt Know there was one yet.
Old Oct 26, 2004 | 09:26 PM
Yeah there is one in marietta off of lower roswell road called KARS. If you want the phone number or contact info let me know. I will PM it to you. The other day they had a heads and cam 2001 TA there getting ready for the sts kit to be put on this week. It will be done friday hoping to go back and check it out. they said it would put around 600RWHP. Thats sweet.
Old Oct 26, 2004 | 09:40 PM
WOW P.M. The info if you don't mind. Did you ever get the leak fixed? How much boost are you running? How do you like the kit so far? I hope to get an STS kit for my truck around the first of the year. Any input would be helpful.
Thanks
