Help ... I'm losing hope with this SC stuff
Old Nov 13, 2004 | 05:43 PM
Fierce-LS1's Avatar
Default Help ... I'm losing hope with this SC stuff
Well once again ... my f&ck%6g ATI damper rotated off the crank. Eveytime it does this, all my belts get messed up including the AC and the accessories belt because it misaligns everything.
HOW do I get this damn thing to stay on. I can never enjoy my car becuase something always breaks or goes wrong
How much torque should be applied ?
Old Nov 13, 2004 | 08:01 PM
LordFlux's Avatar
Are you talking about the ATI SuperDamper? Did you pin the crank?
I'm running the ATI SuperDamper, pinned the crank, and used an ARP crank bolt. Didn't have a torque wrench, but the car was up on a lift and when tightening the bolt, I really got down on it.. put all of my weight into it. I'm not big & buff, so I probably only torqued it to 200ft/lbs or so... I haven't had any problems.
Old Nov 13, 2004 | 08:13 PM
HellRaiser's Avatar
Hey bro don't have any info for ya. But I can tell you once you get all the bugs fixed it will be WORTH IT.... I went threw the same thing with my cars. I am sure almost everyone has at some point in time. But once you get it running perfect it just makes it worth while.
Old Nov 13, 2004 | 09:25 PM
kp's Avatar
kp
You have to pin the crank with that damper, if you dont it will come off. Pin it and use a fresh stock bolt and the factory tightening procedure and it will never come loose again. Hopefully the crank and the ATI hub isnt chewed up after coming loose a couple times.
Once you get the damper to stay on the ATI will be a lot more fun, trust me
Old Nov 13, 2004 | 09:45 PM
Fierce-LS1's Avatar
SHould the damper have come with a pining kit ?
We just finished tourquing it down to 150 ft/lbs. Not sure about the pining
I used the stock bolt and then there are 3 little bolts that hold the SDCE crank pulley to the superdamper
Old Nov 13, 2004 | 09:48 PM
kp's Avatar
kp
no, but they should have sold you one, its easy to do once the damper is off so get one and get it done.
Old Nov 14, 2004 | 07:08 AM
NA$TY-TA's Avatar
Exactly what they said.... I had problems with my stock crank bolt backing out.....and i used a new crank bolt each time...... are you ????? If not that could be part of your probelm. The stock bolt is a TQ to yeild bolt that is only to be used once. When i ordered my shortblock i had the crank pinned. I havent had a problem since.
Kyle
Old Nov 14, 2004 | 11:16 AM
Fierce-LS1's Avatar
Kyle
No I've been reusing the bolt everytime ... I'm gonna go ahead and order the pin kit thought and do this the right way
thanks
