Pics of LS1 F-Body with roots style blower mounted
Old 11-23-2004, 07:44 PM
  #81
LS1Tech Co-Founder
Nine Ball's Avatar
JS, mine is a 6-speed. I built the car with Power Tour in mind
Nine Ball is offline
Old 11-24-2004, 02:06 PM
  #82
technical's Avatar
It's not easy to tell from the pictures, but in the third pic it seems like the underside of the cowl is notched about 4 inches back. Is this correct, PSJ?
technical is offline
Old 11-30-2004, 08:38 AM
  #83
2002 Trans Am's Avatar
LS1Tech hasn't worked for me the past couple of days, any updates on this?
2002 Trans Am is offline
Old 12-05-2004, 02:13 AM
  #84
BLASTER's Avatar
up up up....
BLASTER is offline
Old 12-06-2004, 11:26 PM
  #85
blownerator
BlownChevy's Avatar
-the blowers look like Magnachargers because Eaton builds them. They are all Eaton supercharger bodies.
They are Magnuson Housings with Eaton internals
-the belt in the back has a screw you tighten to adjust tension. simple setup, works well.
80K belt life, tension is preset from the factory
-stock drive pulley on Magnachargers is typically a 3.5" one, good for 6-7 psi. I have a 2.90 pulley on mine, it makes around 8.5 to 9 psi.
Yeap!
-cooling system is all external. There is just an IC inside the manifold, and the hoses go into and out of the manifold to an external resevoir, then into an electric pump, thru the heat exchanger (mounted to front of radiator) and back into the intake. You can fill that resevoir with ice if you wish.
Yeap!
-the hp limits of this setup are based on how much air it can move. 500-530 rwhp would be about the max of them. You could slap it on a 427ci LS1 and it wouldn't make more power, it simply couldn't feed that size engine enough air.
Actually the restriction is not the blower, it is the stock TB and MAF, but then what do I know .
BlownChevy is offline
Old 12-07-2004, 12:04 AM
  #86
Restricted User
CAT3's Avatar
BlownChevy- Thats some good info there. I am still on the fence for this one. I would love to have a similar setup but really need the extra ower output, like the KB delivers for the Slobrahs! Now, if I could spray ontop of this setup and get the results I needed, it would be glorious....other than the facts 1) it wouldnt be a single PA 2) I could get more power out of a traditional centri blower setup to make that power for less...But I love the instant torque, and quite frankly the look!
CAT3 is offline
Old 12-07-2004, 11:07 AM
  #87
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,160 Likes on 754 Posts
Updates are coming, in about a week or so.
Pro Stock John is offline
Old 12-07-2004, 12:08 PM
  #88
BLASTER's Avatar
Doh! I swear you said that two weeks ago . I guess no blower for Xmas I just got a bonus yesterday and it's burning a hole in my pocket. My boss told me to spend it foolishly.
BLASTER is offline
Old 12-10-2004, 06:52 PM
  #89
granitemonkey's Avatar
TTT, I figured we should keep this current.
granitemonkey is offline
Old 12-10-2004, 10:41 PM
  #90
Richiec77's Avatar
That's one cool boss.
Richiec77 is offline
Old 12-11-2004, 11:19 AM
  #91
Boosted One's Avatar
Does anyone know if a KB blower will bolt on to the eaton bolt patern? In other words when the lightning/cobra guys bolt on an upgraded charger do they have to change the intake?
I'd like to put down 600rwhp and I love the twin screw setup's so I was thinking of a magnacharger intake and a kenne bell charger, if the pully's would come out somewhere close. I'm gonna have to find a lightning/cobra to do some measuring on.
Nine Ball, would you mind taking some measurement's for me off of your 1st gen??
Thanks
Frank
Boosted One is offline
Old 12-13-2004, 08:27 PM
  #92
Thanks
Frank
TTT
Old 12-16-2004, 01:49 PM
  #93
Debian Dog's Avatar
Originally Posted by 8seclt1
why is an intercooler such a big deal?
Air coming in to your motor at 120* is not as good at air coming in at 100*
Debian Dog is offline
Old 12-16-2004, 02:33 PM
  #94
agreed
Old 12-16-2004, 04:22 PM
  #95
black_z's Avatar
To The Top
black_z is offline
Old 12-16-2004, 04:30 PM
  #96
Benjamin Russick's Avatar
I was all over the MagnaCharger thread and now this... Keep us posted!!!!!
Benjamin Russick is offline
Old 12-23-2004, 09:37 PM
  #97
wildta's Avatar
well !!!
wildta is offline
Old 12-23-2004, 10:11 PM
  #98
BLASTER's Avatar
Originally Posted by wildta
well !!!
BLASTER is offline
Old 12-23-2004, 11:07 PM
  #99
Phoenix 5.7's Avatar
i want this, when is it going to be ready? PSJ has been talking about this for probably 2 months.
Phoenix 5.7 is offline
Old 12-23-2004, 11:43 PM
  #100
BLASTER's Avatar
It's been a long week.
BLASTER is offline
Quick Reply: Pics of LS1 F-Body with roots style blower mounted
