80mm Pro-M on a 408 with 18psi?
Old Nov 20, 2004 | 02:08 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default 80mm Pro-M on a 408 with 18psi?
Since Pro-M is making GM MAFs now and since my SD tune gets horrible mileage, I am considering getting an 80mm Pro-M for use as a blow-through MAF. Does anyone have any experience with Pro-M on GMs, or as blow-throughs?
BTW the 80mm is said to support up to 800hp.
Old Nov 20, 2004 | 05:40 PM
Jon @ Speed Inc's Avatar
We have done 845RWHP on a Stock/Screened GM 3.5" MAF
Old Nov 20, 2004 | 08:20 PM
smokinHawk's Avatar
but arnt you running blind at that point because the MAF cant read that high?
Old Nov 20, 2004 | 08:37 PM
onfire's Avatar
Coal Mining Director
It's not a maf problem, the ecm can't read that high. So you crutch it with a PE vs rpm tune with ls1edit...and you tune it too rich so it will not be lean on cold days. Unless Speed has tapped into a 3bar map sensor,etc. but I thought LPE was the only game in town for that.
Old Nov 20, 2004 | 08:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Harlan is making over a 1000rwhp thru two mafs, I would guess they are 3.5 or 4.0" Pro-M units.
Old Nov 20, 2004 | 10:16 PM
XLR8NSS's Avatar
Adkoonerstrator
I believe Harlan is running two stock GM mafs actually. Extra electronics ARE needed for this, not as easy as plugging in two mafs.
His old setup was a single rescaled Pro-M with some fancy LS1Edit work...or whatever software he uses.
Old Nov 21, 2004 | 02:37 AM
red90cobra's Avatar
yep he's running two stock mafs into a driver or something. he told me once but come on, he told me he used pin blah blah blah, not really he said something but I just didn't know what he was talking bout lol. wish I knew as much as him so I could understand.
Old Nov 21, 2004 | 03:10 AM
slow's Avatar
no expierence with gm pro-m's, but the ford Pro-M mafs seem to leave a lot to be desired lately. Back in the day when the 5.0's were popular, the Pro-M maf's were good, but lately i have been seeing questionable outputs from them, and normally have people convert to a drawthough setup with the oem meter, and it works much better.
Ryan
Old Nov 21, 2004 | 08:10 AM
Slowhawk's Avatar
LS1Tech Sponsor
Pro-M's for Stangs are a hit or miss on getting one to work right with your combo.Pro=M was suppose to send us out a 80mm MA over a year ago to test but it never came,so can't tell you how they work on GM's.
Old Nov 21, 2004 | 07:19 PM
technically yes, but for he is looking for better gas mileage....
We will be testing out a 3bar MAP setup soon
Old Nov 21, 2004 | 07:25 PM
Evil F1 SS's Avatar
Would that be on my car
Old Nov 21, 2004 | 08:53 PM
hellbents10's Avatar
LS1Tech Sponsor
A 3 bar would be the way to go cause the PCm doesn't know what to do with these high MAF values. It would be cool to ahve a nice easy 3 bar to convert or adapt too, I am dreaming right now though.
Old Nov 21, 2004 | 08:54 PM
LS1Tech Sponsor
I agree on the PE vs RPM though. Just tune it like a carb to be a little rich so when there is some super cold air it doesn't go lean.
Old Nov 21, 2004 | 09:03 PM
romanss's Avatar
Yaa, I've had Harlan talk to me too. It sounds like the teacher in Charlie Brown. mwua mwua mwua mwua.
I realize how dumb I am when I try to listen to him. " yeah I use a triple crossover with a pull down to a square wave convertor "
But I am definately impressed with the whole setup that the guys have accomplished. The Stenod crew has it going on. Harlan is a nice, smart, gifted guy, that doesn't know how to drive Canadian Beer.
Roman
