Few races then Waste Gate falls off? WTF
I'm racing a friend tonight. First i raced a friends bike (2004 Yamaha YZF R6) W/ exaust. The bike is rated at 10.7 @ 125 bone stock. I put approx 2 cars on him and kept pulling. Also raced my friends sentra SE-R. His car went 11.7 @ 118. Put a really bad hurtin on him. 10+++ cars lol. Then... Yes, as you read in the title, my waste gate desides to fall off. While im in 4th gear the power just stopped. I let off and tried to get on it again, but no power and no boost. I heard it dangling on the pavment. Drove slowly to my house and it finally fell off......What this means is time for the TTI race kit headers to be purchased before summer But i still don't understand how the gate fell off. It ripped the welds right off the pipe.
I have the same kit and I had a cracked weld on the log and also a small hole in the weld where the BOV is mounted. Luckily APE fixed the log for me and I fixed the hole at the BOV myself. I guess I should check my wastegate flanges in the spring. I am doing a small upgrade to a Tial 38 so I might be re-doing some plumbing anyway. Im thinking of going to atmosphere off the gate to keep the turbulence down after the turbo. Some people say it helps spool a bit, only one way to find out? Michigan has no inspection.
mark
the way stainless is welded has alot to do with it. especially welding around in a circle. If you do weld something round (circle), your supposed to stitch weld it and allow it to cool some as your doing it. if you just weld it right around, stainless has a tendency to crack, not a big crack, might not be noticable, but in time, weight on it and vibrations it will shear right off. Im a pipe welder and repair alot of large stainless coolers that do the same thing. either use thicker material, or incorporate some kind of gusset or brace.
