Turbo sputter
Old Nov 28, 2004 | 08:30 PM
MelloYellow's Avatar
Default Turbo sputter
Just a Q for a friend.
If he has added a new wastegate and increased boost level 2-3psi, but is now hearing a sputtering noise at higher RPM's... what might it be?
Kind of a fluttering sound.
TIA.
Old Nov 28, 2004 | 08:56 PM
dynedta's Avatar
chronic masturbator
is it only when he lets off the pedal? maybe compressor surge? just a shot in the dark
Old Nov 28, 2004 | 10:42 PM
Thx, can someone define compressor surge?
Read up on it a little.
Looks like he has a factory blow off valve.
Maybe it is opening too soon and he needs to replace it.
Old Nov 29, 2004 | 04:03 AM
HellRaiser's Avatar
What kind of car?
Old Nov 29, 2004 | 06:27 PM
White_Hawk's Avatar
If it happens when you let off the accelerator under boost, it is the sound made by the air passing back through the turbo. A good BOV will get rid of this. It is not the best thing for the turbo's to stall the compressors with the backflow of air. A good hard high boost slam can take out your turbo too (don't ask me how I know).
-Geoff
Old Sep 19, 2005 | 11:42 AM
Tork's Avatar
I have the exact same problem! I have tried different vacuum sources, different BOV tensions (mine's adjustable) and even tried out a $300 bov instead of my $100 one and it still does it? It never does it under low boost or half throttle. Only happens at 3/4 to full throttle and even then it is about 50% of the time. I'm out of ideas. Sorry to jack the thread but any answer I get will probably help. Could it be I need two BOV since one isn't dumping enough air? Anybody?
Old Sep 19, 2005 | 11:44 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
If your on the throttle and its making noises then its not the BOV. Sounds like compressor surge. What engine is this on and what turbo is it?? We can get further into it, but we need more details.
Jose
Old Sep 19, 2005 | 11:55 AM
Tork's Avatar
For mine, I have twin Garrett t3/t4e's, .69 exhaust, running 6-7psi on a 2002 TA LS1 M6, and it's only when OFF the throttle. If I get into boost at 1/2 throttle or less, no problems, the bOV fires perfectly. When I'm doing a heavy pull, 3/4 throttle or more, it's totally fine and pulls like a freight train but when I shift, 50% of the time it surges back. Like I said, I've tried everything I can think off and nothing seems to help.
Old Sep 19, 2005 | 11:58 AM
LS1TECH Sponsor
What BOV are you running, and where did you place it?? Location is very important.
Old Sep 19, 2005 | 12:12 PM
Tork's Avatar
I can't remember the make of mine but I did try a 1.5" TurboSmart Supersonic and behaved the exact same way. Here's a pic of my setup, hope it helps.
Old Sep 19, 2005 | 12:15 PM
LS1TECH Sponsor
You should have the BOV placed pre-intercooler and very close to the compressor outlet.
Jose
Old Sep 19, 2005 | 12:22 PM
Blackbird's Avatar
why pre-intercooler?
Old Sep 19, 2005 | 12:24 PM
LS1TECH Sponsor
Thats your highest pressure point in the system.
Jose
Old Sep 19, 2005 | 12:45 PM
Tork's Avatar
I can move it and find out but you think that will fix it? Seems to easy but I hope so.
Old Sep 19, 2005 | 01:15 PM
LS1TECH Sponsor
We tested BOV's in 2 different locations. Made a difference in performance and sound as well.
Jose
Old Sep 19, 2005 | 01:58 PM
Tork's Avatar
Thanks for the info! I'll let you know how it goes.
Old Sep 19, 2005 | 03:24 PM
ddnspider's Avatar
i always thought you did the BOV after the FMIC because of the drop from the intercooler.do you always put it b4 or just on a twin turbo setup Jose?
Old Sep 20, 2005 | 10:21 AM
Tork's Avatar
Twin or single won't matter since 6psi, is 6psi whether it comes form one or two turbos. But like I said, if it isn't a huge venture for me to relocate it, I'll try it and let you know if it helps.
