what size CI motor are yall running?
Old 12-08-2004, 10:45 PM
ls1ow's Avatar
Default what size CI motor are yall running?
looking at building my first forced induction ls1 to be ready for this next spring been looking at alot of parts, just curious what kinda CI most are using for a say 15-28lbs setup
thanks,
John
Old 12-08-2004, 11:34 PM
cablebandit's Avatar
I am only running 15psi..using 348....346 bored .006
Old 12-09-2004, 01:46 AM
goober35's Avatar
370ci
28psi. LOL i dont think so. You will spend just more in mechine work than u do in parts for the motor. You are going to have to O ring the block and the heads to keep 28psi inside the motor.
Old 12-09-2004, 01:59 AM
Wicked_Hugger99's Avatar
348ci 10-12psi on 93oct & 16-18psi on 110oct
Old 12-09-2004, 10:35 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,133 Likes on 738 Posts
348ci, 14-17 psi in the past, 110 leaded or C16.
New combo should make a bit more power but will still be dynoing on 110L.
Old 12-09-2004, 12:56 PM
Have they dynoed it yet PSJ?
Old 12-09-2004, 01:34 PM
Boostaholic's Avatar
408 CI built by HPE
Old 12-09-2004, 02:15 PM
y2khawk's Avatar
I beg to differ
348 cu in here
Old 12-09-2004, 02:21 PM
Originally Posted by y2khawk
I beg to differ
348 cu in here
Did you not oring your block?
Old 12-09-2004, 02:23 PM
y2khawk's Avatar
nope. 6.0L GM MLS gaskets, off the shelf ARP studs, 317 casting 6.0L heads.
Old 12-09-2004, 03:22 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
360 Cubes, 36lbs boost, no o-rings.......at least not the first time.
Old 12-09-2004, 03:50 PM
eviltwins's Avatar
thanks,
John
How about a real horsepower goal instead of a boost goal. 28 pounds of boost on a pair of T3 60-trim turbos is a hell of a lot less power than 28 pounds of boost on a pair of T72's.
Old 12-09-2004, 04:03 PM
BIGBOS's Avatar
370c.i. motor built by speed inc.
Has about 1000miles on it and running like a champ......15psi with a F1
Old 12-09-2004, 04:31 PM
mdhmi's Avatar
346 CI is all ya really need IMHO.
Mark
Old 12-09-2004, 04:37 PM
Tiago's Avatar
346 here
Old 12-09-2004, 04:47 PM
Camaro_Zach's Avatar
I thought you had afr heads?
Old 12-09-2004, 04:48 PM
NA$TY-TA's Avatar
370 here....
Old 12-09-2004, 05:02 PM
ls1ow's Avatar
thanks for all the info guys 28lbs is not a goal it was just simply a figure i threw out there, knowing that its an extreme amount of boost just curious what kinda of setups are handling it, ill be spending alot more time reasearching what im going to do in the end, but hopefully it will be ready to rock and roll by spring.
thanks,
John Mitchell
Old 12-09-2004, 05:03 PM
NA$TY-TA's Avatar
NOPE............
Old 12-09-2004, 05:13 PM
TApimp's Avatar
Stay stock ci with good pistons and rods, head studs, and very good tuning. Should be no problems
