Oil all over
Old Dec 12, 2004 | 09:54 PM
Mr. Bungle's Avatar
Default Oil all over
I just got home from racing a guy and there is oil all over my engine compartment. I have an ATI DSC1 with 8 lbs of boost. What can be done about this and what causes it. I am new to FI so any help would be appreciated.
mike
Old Dec 12, 2004 | 10:28 PM
SprayJ's Avatar
It's probably coming out of your PCV system, I have the same problem at about 8 lbs. Mine is now vented into a catch can. Hope that helps.
Old Dec 12, 2004 | 10:35 PM
Mr. Bungle's Avatar
Where can i get a catch can and which one do you have and is that all i will need?
thanks
mike
Old Dec 12, 2004 | 10:37 PM
quicksilverado's Avatar
thanks
mike
AMW, one of the sponsers to the right.
Old Dec 12, 2004 | 10:46 PM
Mr. Bungle's Avatar
Cool thanks
Old Dec 13, 2004 | 02:34 AM
HUGGER ORANGE SS's Avatar
Read my Pics in my Sig to find how to setup the Catch Can... The problem is you pressurizing the block with your Blower.. Dont use a Check Valve. Just vent it all to a catch can, and run it to the open air like I do or run it back to the inlet of the blower.
Clint
Old Dec 13, 2004 | 04:47 PM
Mr. Bungle's Avatar
Clint
Nice setup where did you get everything?
Old Dec 15, 2004 | 07:33 PM
I got everyting from everywhere. Are you talking about the Catchcan setup or my entire setup..
Clint
Old Dec 15, 2004 | 07:36 PM
Get the Catch can on E-bay. A non Greddy catchcan like mine will run you 50 bucks.. Follow the instructions and cap off the passenger side of the intake. Get rid of the pcv system and run your catchcen to the open air like I do or run it back to the blower inlet, before the blower so it will suck, If you put your vent system after the blower at all your pressurize the block and keep popping up your dipstick.
Clint
Old Dec 15, 2004 | 08:06 PM
Slowhawk's Avatar
LS1Tech Sponsor
I just run the tubes down under the car with no catch can on most of the cars we add force induction too.
Old Dec 15, 2004 | 10:21 PM
Kaneman's Avatar
I had the same issue on my old motor and it ended up being a broken ring galley.
Kane
Old Dec 16, 2004 | 05:59 AM
Mr. Bungle's Avatar
Kane
God i hope it's not that. How did you finally know that that was the problem. What were they signs?
Old Dec 16, 2004 | 06:00 AM
Mr. Bungle's Avatar
Clint
Thanks for the great info i will probably pm you when i go to hook up the the catch can system.
Old Dec 16, 2004 | 07:03 AM
natesiy's Avatar
Just had the exact same problem. Tried the catchcan, breathers, bypassing the PCV valve... nothing.
Found out that 3 of the 8 pistons had chipped rings.
Old Dec 16, 2004 | 09:35 AM
618HAWK's Avatar
I take it this is a common problem for most forced induction setups. At what point of prs-boost dose this seem to happen. Is it just more common to higher boosted engines vs ones that keep it down low, say around 7-9 psi.
Old Dec 16, 2004 | 10:38 AM
MelloYellow's Avatar
Is your oil dipstick lifting & spraying?
Where is the oil coming from?
Old Dec 16, 2004 | 03:11 PM
I had my dipstick pop out as well 2 years ago. Turned out to the a hole on the side on the #6 piston.. Rebuilt motor!! Now my #6 piston is my paper weight in my office... I tell people this is what happens when you run too lean! Stupid ATI FMU and Stock Injector setup!!! Damn FMU was faulty and caused me a good chunk of change to rebuild my motor..
Clint
Old Dec 16, 2004 | 05:29 PM
Mr. Bungle's Avatar
Yeah the dipstick lifted and sprayed oil everywhere. I am hoping that i don't have to rebuild the motor but it's not sounding good.
Old Dec 16, 2004 | 08:12 PM
BlwnTA's Avatar
7 Second Club
Yep, save all your Christmas money. I have been there as well, broken ring lands on 2 pistons. Let me guess, your car probably runs fine under 3500 rpms.....right, but when you get on it hard it probably chokes and loses some power and spits oil thru the ATI piping and maybe blows the dipstick out. I hate to see it happen to anyone but your not alone by any means. It's how us rookies learn.
When you rebuild it make sure to pressurize the oiling system before rotating the shortblock at all.....I'm on my second lesson after 500 miles on my new motor....this time W2W is building it!
Old Dec 17, 2004 | 12:34 AM
As others have said in the past, do a compression test and cross your fingers.
