STS on a 2004 GTO almost done
LS1Tech Sponsor
We are almost done tuning in the preproduction GTO kit from STS.This kit is awesome.The fit and finish is great.The car is an A4 with a 3200rpm stall and small Cam.There is no lag!You can brake boost it to any boost level for launch!Just would like to thank STS for there setup and great customer service in getting everything I needed in time
This kit is extremely quiet inside the car also.Well,till your under boost
Wow that looks great, I posted a few days ago about STSing an '05 GTO, looking from the piping under the car the only thing STS will have to change is the tune, all the hardware from the '04 looks like it should marry up just fine to the '05. And if STS does make a kit for the '05 man it is sooooo mine, I'll go get a GTO and a month later slap on the STS. I can only image the numbers. I ran the math the other day and it should be around 540HP to the ground on the '05. Looks like you should make about 460+HP, am I in the ball park? or is yours a bit madd man?
LS1Tech Sponsor
Originally Posted by Jammer
Gotta line it up with the goat we have at east side right now...traditional H/C vs basic STS... should be good!
LS1Tech Sponsor
Here is the final dyno.Stock against 8lbs against 10lbs. Tranny wasn't holding too good with the power.
Very clean!!!
I like the HP curve
Was the stall chosen when the car was N/A then the STS added or was it built with the STS in mind? IE is it still a 3200 stall or is it effectively higher now with the abundance of TQ?
I like the HP curve
that goat!!!!!
