expanding intake pipe!
Old Dec 25, 2004 | 08:05 AM
ChevyCoonass's Avatar
Default expanding intake pipe!
Hey guys, I just got my Procharger put on my truck and I have got a question. I am pushing about 13psi. of boost, and when I give it gas from under the hood, my intake pipe after the intercooler is expanding big time. I made it out of some 4" rubber elbows and aluminum 4" tubing. At first I was popping seams everyday, then I put some Tbolt clamps on the seams and that seems to do the trick. But when I get into boost, the rubber elbows look like they are going to blow up! Am I loosing boost by wasting energy on making the rubber swell? I do have about 8 rubber elbows. Does silicone hose for turbos not swell as much? More stable? Any suggestions?
Old Dec 25, 2004 | 09:31 AM
GMC SKI's Avatar
that elbow going into the intake Is Crap I suggest going with two 4" mandrel exhuast pipes with some 4' silicone couplers
That whole Ati kit is pretty Crappy In my opinion
What size pulley are you running ?
Old Dec 25, 2004 | 11:57 AM
libertine1015's Avatar
Silicone hoses, elbows, ect.. for induction are reinforced by fibers between the layers kind of like high pressure hoses. Definately the way to go. Try HTS they have high quality stuff.
Old Dec 25, 2004 | 12:12 PM
Arkangel77's Avatar
hear is a Link. 5 pages of stuff, I bet you can find what you need just by looking. Lata, Ark
http://search.ebay.com/_W0QQsassZhig...sortpropertyZ1
Old Dec 25, 2004 | 03:00 PM
Lafngas98Z's Avatar
I found a great place for you FI guys to get mandrel bends, rubber couplers etc. Check out www.airflo.com
Old Dec 25, 2004 | 03:15 PM
hellbents10's Avatar
LS1Tech Sponsor
ATI
"The system sucks...but the headunit is TOP NOTCH!"
Old Dec 25, 2004 | 07:29 PM
frcefed98's Avatar
Originally Posted by hellbents10
ATI
my wallet can vouch for that
Old Dec 25, 2004 | 09:58 PM
hey GMC SKI, I am not using the ATI kit on the throttle body. I bought some rubber elbows in 45º and 90º cominations, with aluminum tubing connecting them. I bought it all from www.airflowonline.com I basically wanted to know if silicone would be stiffer than the rubber. The rubber is very thick but very soft as well.
By the way, no one mentioned anything about if the swelling of all of these joints really looses boost or not. Please comment.
Old Dec 25, 2004 | 10:06 PM
I just checked out airflo.com and it links you to the same place where I bought my rubber elbows. They are strong, but I guess 13lbs. boost is too much for them to handle??
Old Dec 25, 2004 | 10:15 PM
Arkangel77's Avatar
I am no Expert BUT I would say NO expanding elbows wont cause you to loose BOOST!
AND yes The Silicone stuff will not expand anyhting like the rubber does. Not sure if its stiffer BUT it will not expand!
Old Dec 25, 2004 | 11:36 PM
NA$TY-TA's Avatar
You can loose some boost........ my intake would swell on the dyno like a huge baloon....... and near peak boost it would just stop rising way to early...... then on the next run it would blow off....... the swelling is not a good thing........ Give Jim @ High Temp Silicone (HTS) a call he will take care of you.
Kyle
Old Dec 26, 2004 | 12:48 AM
black_yukon's Avatar
Another recomendation here for HighTechSilicone, quality stuff and Jim is great to deal with.
Old Dec 26, 2004 | 09:52 AM
Thanks guys. I think I will get rid of at least 2 of my elbows and use welded mandrel bent piping and then get silicone couplers with tbolts. That should take care of it.
Old Dec 27, 2004 | 10:41 AM
mongse's Avatar
I ruin the end of films...
I've bought quite a bit from Jim @ HTS too.
Rubber elbows on ANY forced induction is a bad idea. Get some mandrel elbows and silicone couplers to do it right.
Old Dec 27, 2004 | 11:05 AM
LS1Tech Sponsor
I agree there. mandrel elbows and silicone couplers=no worries.
Old Dec 27, 2004 | 11:17 AM
Arkangel77's Avatar
Where is a Good place to BUY mandrel elbows?
Old Dec 27, 2004 | 11:24 AM
mongse's Avatar
Copied from the local board where I'm a mod...
have fun!
Old Dec 28, 2004 | 08:43 PM
Hightempsilicone's Avatar
Thank you all for the kind words!
The fact is that a reinforced silicone hose will always outperform any non reinforced rubber elbow in all regards except for price. Silicone by nature is a weak material, but by reinforcing the wall with 4 plies of woven fabric we can achieve a much higher burst pressure. Nitrile elbows are good to about 220ºF but after that they tend to take a pretty steep compression set. I would NEVER use EPDM on anything but coolant under the hood. Oils and Fuels aggressivley attack EPDM and it wouldnt last.
By far the cheapest method is to use a mandrel bent tube, 2 couplers and 4 t-bolts (If you can get the bend under $20.00). If you cannot get a good deal on the bend, it is cheaper to go the silicone elbow.
Jim
Old Dec 28, 2004 | 11:04 PM
Arkangel77's Avatar
Man the Pipe I need I cant find and I dont think I am able to make it Myself. MAN I wish I could weild! I May try a Mufler shop and see what I can get made? I Just dont know of any place that does Mandrel bends down hear in New Orleans?
I need a 90 thats more like a 105 degree but then goes stright down after the bend!
I may Buy a 180 and Cut/fit it and then get it welded! That may work?
