its a dog?????
Old Dec 26, 2004 | 04:50 PM
procharged hd's Avatar
Default its a dog?????
installed a procharger on my 6.o hd falls on its face and runs like crap till about 4ib of boost than runs like hell any ideas????
Old Dec 26, 2004 | 05:54 PM
BlwnTA's Avatar
7 Second Club
TUNING is needed.
Old Dec 26, 2004 | 05:57 PM
XFACTOR's Avatar
Get it tuned and it will help you out alot.
Old Dec 26, 2004 | 06:25 PM
HellRaiser's Avatar
Originally Posted by BlwnTA
TUNING is needed.
what he said....
Old Dec 26, 2004 | 06:51 PM
what tune do u guys recomend?what size of injectors do u guys recomend?
Old Dec 26, 2004 | 07:05 PM
GMC SKI's Avatar
You need to ditch the FMU and upgrade to a set of marine injectors which are about 43lbs
You can get the injectors at racetronix's there a multec2 injectors
After that i would reccomend getttin a tune or buying Hptuners or ls1edit
Where about do you live ?
Old Dec 26, 2004 | 07:06 PM
HellRaiser's Avatar
Get it tuned on the dyno by someone. As for injectors go, I think it depends on how much boost you are going to run. 5psi you might not need then but anything over that I think most people go with 42lber's
Old Dec 26, 2004 | 07:09 PM
XFACTOR's Avatar
Are you getting any detonation?? I would say get a custom dyno tune and some 42# injectors and turn up the boost!!!!! ALso do you have a stall converter??
Old Dec 26, 2004 | 07:28 PM
Right now i have the 8lb pully on there.i have no detonation and no stall converter.I live about 30 min from ed wright (tulsa OK) but heard that nelson is about the best.That 8lb pully makes about 6lbs or 7lbs so i have a 10lb wating but want to get truck running better first.
Old Dec 26, 2004 | 08:11 PM
XFACTOR's Avatar
You need a good stall converter like 3000+for a procharger since they make boost in higher rpm's. Then go get your custom tune done!!
Old Dec 27, 2004 | 09:11 AM
SAM98WS6's Avatar
exhaust?
Old Dec 27, 2004 | 10:05 AM
greentahoe's Avatar
You definately need some custom tuning and larger injectors. I will tell you that the difference between 6 or 7# and 10# is night and day!! With the smaller pulley, you will see boost much sooner and it makes things alot more fun.
