Ring gaps and boost?
Old Dec 27, 2004 | 08:15 AM
Country Boy's Avatar
Senior Member
Default Ring gaps and boost?
When I built my motor, I set it up to take a 200 hit of spray. Ring gaps are .016 top and .018 second. How much boost would I be able to push before I run into ring problems? Pistons are forged flat tops from Diamond.
Old Dec 27, 2004 | 08:38 AM
Z06PSI's Avatar
It seems me and you are always changing are combos at the same time to the same thing for the last 3 years....... I am boosting as well here in about 2 months.
Old Dec 27, 2004 | 08:44 AM
Senior Member
LOL.... I use to be a N2O junkie... well, still am, but Im resisting buying a nitrous kit Once I got the feel of 700 lb ft of TQ I was hooked and N/A is plain *** boring to me. Sure, I can roast the tires through 3rd with my H/C setup, but the pin you in the seat TQ isnt there and I got tired of filling 2 bottles every weekend. I want something thats theres all the time
Hopefully the local guys arent reading this
Old Dec 27, 2004 | 11:13 AM
smokinHawk's Avatar
when i did my rings, i remember the FI and nitrous guides on the ring chart that came with the rings had them at similair gaps.
so you should be able to run some good boost, now what is your CR to me would be more important.
Old Dec 27, 2004 | 06:09 PM
Senior Member
Im running 11:1 now with flat tops and 58cc chamber heads, but I plan on changing the heads and cam. Im think along the lines of the 7xcc AFR heads with thick gaskets.
Old Dec 27, 2004 | 06:22 PM
383LQ4SS's Avatar
I see you Carl!!!!!!!!!!!
Old Dec 27, 2004 | 06:37 PM
S_J_H's Avatar
hmm, I would call those normal N.A. gaps, not n20 gaps.
I use .025 and .028 on a 3.905 bore FWIW.
Steve
Old Dec 27, 2004 | 07:09 PM
Senior Member
DAMNIT!! Shhhhh.....
Old Dec 27, 2004 | 07:10 PM
Senior Member
Steve
The gaps were strait from Chris at Diamond. Hes now owner of APE.. Same Chris. They are plasma moly rings. He said theyll hold a 200 shot without a problem.
Old Dec 27, 2004 | 08:22 PM
gator's 99TA's Avatar
i dont see anything either carl.......but your sekrit is safe with me.
Old Dec 27, 2004 | 10:06 PM
Caveman's Avatar
10 & 11 Second Club
Its kiind of hard to hide a turbo or blower, they sound a little different then na motors.
Old Dec 27, 2004 | 11:39 PM
Lostpatrolman's Avatar
lol, just a little. Just tell people it is a squeeling belt.
Old Dec 28, 2004 | 06:43 AM
Senior Member
Wont try to hide it when Im out, just the build up
Old Dec 28, 2004 | 07:36 AM
WS666's Avatar
I'm sometimes local!
Old Dec 28, 2004 | 07:53 AM
Senior Member
Grrrrrrrrr...
It probably wont be a reality untill next summer though. I have alot of credit cards to pay off first
Old Dec 28, 2004 | 08:52 AM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Switch the ring gaps around and you will be ok. If you are going to spray it all the time you may want to open both gaps up by .002". Even with boost you will be fine running those gaps. If you have any other questions PM me or just giveme a call.
Thanks
