How much boost on stock lower end is to much?
Old Dec 28, 2004 | 06:06 PM
Need2gofaster's Avatar
Default How much boost on stock lower end is to much?
A buddy of mine is looking at a 99 Z-28 with 40,000 miles on it. It has a ATI charger with dual aftercoolers and 9.5 to 10psi boost. The car also has a differnt cam(specs unknown) in it. I told him that sounds like alot of boost for a stock lower end but i could be wrong. Please Give me your 2 cents!
Old Dec 28, 2004 | 06:38 PM
SSmith's Avatar
I'm no expert but I have been sitting on the fence for about two years about installing a ATI Procharger on my weekends only just for pleasure Camaro SS.
Everthing I have read in the last 2 years says on a stock internal engine not to run anything higher than 8 PSI. Now if you have it dyno tuned on the conservitive side of caution and don't drive it when the outside temperatures get above 90 degree's F. than maybe you could roll the dice and run 10 PSI.
Just my 2 cents.
Old Dec 28, 2004 | 06:41 PM
I think you have to consider the hp the car put down also? This guy thats selling it claims well over 600hp with the car running in the low 10's 1/4 mile. that sounds suspect to me on a stock internals with just a cam. any thoughts?
Old Dec 28, 2004 | 06:53 PM
BlwnTA's Avatar
7 Second Club
I made 521/504 at the wheels on 10 PSI and 587/532 at the wheels on 12 PSI a few weeks later on the street it went boom (broke a couple of ring lands).
It may be 600 hp at the crank (475-500 at the wheels). I agree with above...8 PSI and a conservative tune is safe. It gets risky as you go higher than that.
Mark
Old Dec 28, 2004 | 06:57 PM
TwnTrboCE's Avatar
I ran 12psi on my stock bottom end most of a season. Made over 600rwhp and went high 9's in a 3500lb car. There was not a thing wrong with the motor when I pulled it. Tuning has everything to do with it though. It can be done but I wouldn't consider it safe.
Old Dec 28, 2004 | 07:09 PM
BlwnTA's Avatar
7 Second Club
Mike, you are definitely an exception to the rule.
Old Dec 29, 2004 | 10:10 AM
TTSSZ's Avatar
I agree Its all in the tuning. I'm staying at 8.5# and just under 600rw
till I do the shortblock. (did 7500mi so far) Also make sure your fuel system is up to the task, If it leans out on the top end...
Old Dec 29, 2004 | 10:15 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I think 9 psi intercooled works fine. I think that 12 psi intercooled could be on the edge for pump gas. I think 500rwhp is doable, and anything above that requires even more attention to your tune, inlet air temps, and efficiency of your intercooler.
Old Dec 29, 2004 | 10:36 AM
GRT's Avatar
GRT
I have a Vortech kit on a completely stock '02 SS. It came with 8-9lbs of boost. I don't think Vortech will warrant it if it's changed. I dyno'd 417.5 rw.
Old Dec 29, 2004 | 10:47 AM
RICE ETR's Avatar
Turbo Addict
Hey Mike.. just curious if you were using the stock maf? If so then you were obviously outflowing it... did you only make changes to compensate for it in the PE vs rpm? What type fuel and fuel system? What AFR were you tuning for? I was around 10.5-11.1 w/o alky injection, didn't remove and fuel, just added methanol on top of that on pump gas.. and 13 degrees peak torque, 16 peak hp.
Thanks for any input,
-Jarrod
Old Dec 29, 2004 | 12:08 PM
Slowhawk's Avatar
LS1Tech Sponsor
I run my car at 10lbs at 6000rpm and 12lbs at 6500rpm on the stock motor.A/F is set to 10.5-1 to 11-1 across the board.10psi won't last forever though.
Old Dec 29, 2004 | 03:46 PM
LSs1Power's Avatar
U dont need to run alot of boost to make the power.... Im running 8psi but seeing 548rwhp 500rwtq with 19 degree of timing. Its all in the setup. U can get close to 600rwhp with 8psi if done right and thats what im planning to do before i increase the boost.
Old Dec 29, 2004 | 05:23 PM
Got Me SOM's Avatar
air fuel keep at 12:1, keep timing at 18 degrees.
The ringlands are the weak link on the stock bottom end.
I broke a ringland pushing 9 and i had a convervative boost.
Old Dec 29, 2004 | 09:08 PM
TwnTrboCE's Avatar
-Jarrod
Stock maf. Tuned in PE vs rpm table. I was running Sunoco 104 unleaded. Had one intank and one external Walbro running thru the stock lines and rails. With 42lb injectors. I was running it on the lean side. Was spinning it to 6800 also. From what I remember timing was around 20+/-.
I wouldn't recommend doing this though.
Old Dec 29, 2004 | 09:52 PM
Jeremiah's Avatar
My car broke a ring land before tuning was complete, motor was all internally stock, We were pushing over 13#.
I was told by SDConcepts I would see no more than 10# max.
Old Dec 29, 2004 | 10:44 PM
RICE ETR's Avatar
Turbo Addict
he he... I don't think I am that lucky.
Thanks for the info!
Old Dec 30, 2004 | 12:51 AM
Zombie's Avatar
where any of you guys who broke ringlands running any type of logging software at the time? Do you know if it saw any knock (the ECU, not your ears).
Doubling the output of a motor only stresses the internals about 15-20% more than stock, but if you detonate i can be in the 1000% range. The motor will get tired faster though making more power and running it hard.
Old Dec 30, 2004 | 12:30 PM
Got Me SOM's Avatar
No knock here, gotta remember these are CAST pistons and they are not designed for boost. Something's gonna give eventually.
Old Dec 30, 2004 | 05:01 PM
Zombie's Avatar
yeah, i know, i fear it. Thats why I was asking. I've tuned a lot of boosted cars, but they are usually built to some level. I always tune safe on a stock motor. My target a/f on the street is 11.0-11.2 with conservative timing.
I just picked up my 2000 SS STS car today. I'm retuning it tonight to help with some of the cam surge it has at lower RPMs. At 5 psi it's out of fuel at 6000 rpms (leans out to 12.1). I'll hopefully be throwing the walbro in it this weekend, next weekend at the latest. Until then i'm just taking it easy.
Intercooler will be going on before summer, will run 7 psi max on pump.... if it can do it in our vegas temps. Ran 5psi ok, but could barely get any timing in it during 100+ days. IATs were as high a 170.
