strange miss under boost STS kit
Old Jan 9, 2005 | 08:32 PM
Zombie's Avatar
Default strange miss under boost STS kit
My car has a STS setup on it and i'm now getting a miss under boost. The problems all started last monday when it rained here. I know i sucked up some water cause I got a maf error (we had a lot of flooding). Let everything dry out and the next day the car was fine.
Wednesday the car started to miss under boost, problem got worse on thursday and friday. On sat it was missing during normal driving too. I swapped the autolite 103's for some NGK TR6's. Gapped them to .030, old autolites were .035. That solved the normal driving miss, but it still misses under boost. At part throttle boost it will miss less often, but under WOT it will miss very bad, sounds like the spark is getting blown out.
So far i've swapped, o2's, plugs, wires and maf. Does anyone have any other suggestions. Could I gap the plugs less than .030. I've only run into these sorts of problems when running higher boost (12+ psi) on other cars i've owned.
Old Jan 9, 2005 | 08:59 PM
F8L Z71's Avatar
12 Second Truck Club
Is there an intercooler on this car? Have you cleaned out ALL of the piping?
I had the same problem on my truck and I had a **** ton of water still in the intercooler and there was some still trapped in the piping.
Could have shorted the MAF too?
Old Jan 9, 2005 | 09:31 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would say water still in the pipes.Just disconnect the lowest pipes and see if water comes out.
Old Jan 9, 2005 | 09:34 PM
Boostaholic's Avatar
I had this problem and it was a coil pack grounding issue.
Old Jan 9, 2005 | 09:35 PM
Is the miss on just 1 cyl, bank or all of them at random?
Old Jan 9, 2005 | 11:08 PM
Zombie's Avatar
miss is random, I checked the pipes when I had the car on the lift today and I didn't see or feel any water in them. No intercooler on the car yet.
How can I check for a coil pack ground issue?
Old Jan 10, 2005 | 04:47 PM
Zombie's Avatar
anyone else have ideas? I hate not being able to boost.
Old Jan 10, 2005 | 04:51 PM
bradyb's Avatar
clean your MAF too, take it out and spray it with parts cleaner. Did you have the water proof precharger over your filter?
Old Jan 10, 2005 | 05:29 PM
2001WS6Vert's Avatar
I had a miss only under boost which was a coil. Log the data to see which cylinder is mis-firing and then switch coils to see if the mis-fire follows the coil.
Old Jan 10, 2005 | 06:00 PM
Zombie's Avatar
Yes, the filter had it's cover on, but it doesn't do much good when there is flooding. I've already replaced the maf with another one.
I'll data log it again tonight to check for the missfire.
Old Jan 10, 2005 | 11:17 PM
Zombie's Avatar
Scanned the car tonight. The miss is ONLY on #5 and #6.
Suggestions? Swap the coil packs? Is there any common wiring between 5 and 6?
Old Jan 11, 2005 | 07:49 AM
When I was trying to diagnose my mis-fire the data also showed a mis-fire on two cylinders (though I only had 1 bad coil). I guess its just not that precise so it was showing a miss over two cylinders. The really weird thing was that the bad coil was one cylinder past the later one in the firing order showing the mis-fire. So the culprit cylinder was not one of the ones that the data log showed. It took me quite awhile to figure out because of this.
Old Jan 11, 2005 | 07:55 AM
Don't leave cylinder 4 out of the coil swapping (trailing cylinder in the firing order). If your experience is like mine was that could be the one. Of course also swap 5 & 6. At least that will rule out the coils.
Old Jan 12, 2005 | 12:48 AM
Zombie's Avatar
Ok, swapped coil packs, 2-4, 6-8, 1-3, 5-7.... still have the exact same miss fire
I guess swapping injectors comes next, then swapping the ECU. After that i'm SOL I guess. Man this is frustrating! I just wanna experience boost again!
Old Jan 12, 2005 | 12:56 AM
goober35's Avatar
In stead of swap side of the coils. See if you can barrow a set just to see if you have a bad set. If you live in the DFW you can borrow mine just to see.
Old Jan 12, 2005 | 07:02 AM
So the miss stayed on the same cylinders as before I assume. Did you try the switching the wires around too? I would put the ECU way down on the list of probable causes, very unlikely.
Old Jan 12, 2005 | 07:14 AM
Slowhawk's Avatar
LS1Tech Sponsor
I would check,plugs,wires,valvetrain.Then next would be the piston's.
Old Jan 12, 2005 | 10:16 AM
Zombie's Avatar
i'll try the plugs and wires tonight when I get home. I'm trying to change only one thing at a time so that I can narrow down the problem. The car drives great as long as I don't boost.
I really hope this is something stupid and simple. Last thing I want to do is pull valvetrain crap.
I'm gonna swap a few plugs and wires and also regap some of them to .025 to see if that clears up the problem. It really feels like spark blow out.
Old Jan 12, 2005 | 10:46 AM
White_Hawk's Avatar
Time to run compression and leakdown. If you know what cylinders are giving you the misses, it should be pretty easy.
-Geoff
Old Jan 12, 2005 | 11:28 AM
3800SII's Avatar
I had a problem like this also. I don't know if an Ls1 has an ignition control module, but
that was the problem on my 6 cylinder Firebird. Everything else was checking out perfect but it misfired horribly.
